New Toys have arrived
I could'nt stop myself but to jump up and abt that my new parts have arrived today. 1) GPS and 2) Compass. Once I get my comm module moved over to a dedicated Cog tonight, I should start looking into these two. One at a time [noparse]:)[/noparse]
I still need to see how I'm going to assemble my parts on ALIBE.
I must say, on a side note that Chris Savage in Tech support was awesome in help answering various range of questions and recommendations. I must say yet again, Parallax Support Rocks!!
"any small object, accidentally dropped, goes and hides behind a larger object."
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://ALIBE.crosscity.com/
It is also worth mentioning that not all applications need the combination. For example, let's suppose you're only interested in capturing the NMEA data (l/l/a) for stamping Pictures' EXIF data, one would normally not care for compass info and therefore will not need compass features there.
I believe to keep the cost-to-make and price-to-buy under control, they are usually kept separate.
hope that helps answer your question
Charlie
·· In fact, due to drift/error it’s possible for a compass module to report inaccurate heading…Picture the GPS triangulating your coordinates at point X,Y then on the next scan X,Y-3…Now it appears that you’re moving backward and you haven’t moved at all.
Chris Savage
Parallax Tech Support
Drift in an aircraft, for instance.
James L
Bearing: the direction from you to another point, such as a waypoint or incoming torpedo (measured with a transit or sighting compass).
Heading: the direction you're moving (measured with a GPS unit).
Azimuth: the direction you're pointed (measured with a compass or gyroscope).
I had to look them up. I can never seem to remember which is which.
It kind of annoyed me a bit, but I was considering getting one of these anyway, although I did want to have a look at one in the flesh first. Fate steps in and I end up with new toys. Bugger. The wife'll not believe it was a mix-up though, she'll just see more "nerd toys" around the place and another transaction on the bank statement.
But it's perfectly acceptable to "mix-up" buying $100 worth of make-up (which is a consumable, not an investment)!!!!!
Regardless of how you explain it, your Azimuth will not coincide with her view of your Bearing, and thus you will be Heading toward a fight (unless she's a nerd too, in which case I envy you!).
Sorry, I couldn't resist the cheesy joke...
-Parsko
She's not particularly nerdy, but does take an interest in what I'm tinkering with from time to time, but that's mainly the more visual stuff. She's a primary school teacher, and I'm probably the biggest kid she has to deal with each day.
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
