SuperCap use
Stumbled on this "hack" for using a supercap to give 9volts for 3hours (small loads obviously) and only requires 20seconds to charge.
....might be some remote sensor uses...
handhelds.hackaday.com/2005/12/06/supercap-9v-battery/1
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Steve
I'm sure it's not much more than the supercap as the battery source, then running a typical 9Vbattery circuit with some series current protection.
Steve
Paul Baker
Steve
Seems like they are assuming an LED light source of some sort.· 3 hours still seems quite dubious for anything useful.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 10/24/2006 4:18:14 PM GMT
Paul Baker
Still, 10Farads is hefty and really begins to be useful as a backup for BS2's, the SXes, or the Propeller.
The main problem I had was not the discharge, but the inrush from charging having potentially damaging effects. To a power suplly, it looks like a dead short. In the concept of a backup supply -- One must put a current limiting device on the charge side and blocking diodes to avoid having discharge seek a wrong path. The diode causes a volage drop, so you may either have to provide a voltage that is adequate for the regulators or you have to bypass the regulator. In some cases the regulator won't cause a low-voltage drop out, but the BS2 is set at 4.6volt shut down.
I guess several could be used in series to up the voltage without a solidstate device. Seems like 3 would be enough as 9V has always been a wasteful alternative, but package of convience.
My guess is you could get 20ma for a resonable window of time to get power back to the device.
Also, don't discount the value of a device that can give your project a little extra to perform an "orderly shutdown". I could see something like this even being enough for the Stamp to signal or even "call" (cell phone, land line, packet radio, etc...) its "help me!" message before going into a low-power state...again with a reasonably orderly shutdown...
hmmm...
Truly Understand the Fundamentals and the Path will be so much easier...
http://www.elektor-electronics.co.uk/Default.aspx?tabid=28&year=2003&month=-1&art=50470&PN=On&SearchText=
...BUT it can be found here also for free!!!
http://fussychild.net/2005/precollege_saturday/Spring06/10-2003%2520SuperCap%2520Battery.pdf
Thanos
Greekbotics: Greek Robotics Forum
(Translate it using Babelfish)
Post Edited (Tronic (Greece)) : 10/25/2006 2:27:32 PM GMT
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
This circuit is also commonly used with solar cells for battery recharging purposes.
...Could also be used with Peltier devices to thermally recharge batteries.
You can also experiment with different coil ratio's to change the efficiency.
Google "Hartley oscillator" or "Colpitts oscillator" as this is really the heart of this circuit.
Beau Schwabe
IC Layout Engineer
