Converting data to serial or analog
I am working on a data acquisition/display project. When finished, I want to have a small device that logs data to an sd card and displays selected data on its 8 digit led display. I have the display working and I am pleased with it (thanks Nuts n Volts). I have used the maxim 8 digit driver and looked at example code from parallax. Right now it is being used to display heading and speed in my car·and it has been used as a clock(time from gps signal), acurate to the 1/10th of a second (useless, i know·
) in my room. The sensors that I currently use are the memsic 2125 2 axis accelerometer (pwm), 2 infrared temperature sensors from melexis·with pwm output and my 5hz serial gps with adjustable baudrate serial output.
So there is an SD data logger that I am considering using, but·input data has to be·one channel·serial data·or·up to 10 ADC channels (im assuming this means the signal needs to be a varying voltage from 0-5??). My gps is serial but my other sensors are not. So I guess I need to either come up with a way of sending all·of these signals in one serial line or convert them all to analog data.·What do you guys think. Is this possible and what is the best way? The whole point of this is to free up signal converting from the stamp and use it to just run the display and a few input buttons. The stamp can't output an analog signal so it wouldn't help with·ADC and it can't output all that serial data fast enough for the logger to reach its full potential. The logger will accept up to 38400 baud so the stamp will really limit its logging speed.
What do you guys/gals think? Is there·some sort of a converter chip out there that·could help me?
The logger is at: http://www.sparkfun.com/commerce/product_info.php?products_id=752
Brian
Brian
The stamp will read your gps and any other sensors you want to use then send it out to the SD device in the form of a serial string on one pin.See the SEROUT help file. Serial speed is relatively unimportant and a good choice would be 2400 or 4800.
I used this technique on a research boat and was able to read gps, depth, water temp, water quality measurements, time, battery voltage, plus a bunch of other signals.
Cheers
Tom Sisk
http://www.siskconsult.com
Are you doing something with all that data in real time? Also, is your gps really calculating a new position at the 5HZ rate? You may have to trade off some speed of updates in exchange for a system that has time to do the real-world stuff. Any chance of more detail of the overall project?
With so much data being stored, there must be some off-line processing afterwards,no? How about using two SD units; one set to store the gps data via serial communication and one set to do the ADC stuff. During post processing, you would use the time track to sync the readings.
Or, is realtime control the over-riding concern in which case, more processing power (maybe a Propeller) may be the answer.
Tom Sisk
The only real time thing I am doing with the data is displaying it and that only needs to be at 1 or 2 hz.
Yes the gps is actually sending a new set of data (velocity, position ect.)·5 times a second. Its a garmin gps-18 5hz.
The project is just a data logger and display primarily for use in·testing cars. I can post a concept picture of it when I get to my home computer. I have been using stampDAQ to log raw data into excell in order to get reasonable sample rates (5 hz or less). This requires a laptop to be in the car and swapping it for a card reader would save me a lot of hassle. After the data is in excell i use equations to turn it into actual values and then graph. I know very little about the propeller but would be willing to give it a try. I just learned the BS2 last summer using "What is a Microcontroller", so the propeller may be over my head...
Brian
Post Edited (Brian Smith) : 10/26/2006 1:53:09 AM GMT
·· I like the planning that went into the sandwiching of these boards together…I recently did the same thing with two boards that were made at different times but designed to sandwich together.· The project will be posted soon, but the concept is the top board is the display board while the main PCB underneath is the controller board and also contains the MAX7219 driver for the display.· I didn’t use conventional headers/sockets for my connection though as you can see.
Chris Savage
Parallax Tech Support
