Integrating BS2p and VB
I·have·most of it integration working good but the only problem I'm having is reading the code coming from the stamp·into Visual Basic.· Does anyone have any examples of an easy way to accomplish this?
Justin
Justin
i found a a page that has done this very simple
http://www.rentron.com/receiving_data.htm
good luck!
may the stamp be with you
Are you setting the DTRenable to False within VB?
Beau Schwabe
IC Layout Engineer
PC --> Waiting to send commands
BS2 --> Waiting to receive commands
PC --> Send request for permission to transmit command sequence
BS2 --> Grant permission to send command sequence, await MainCommand
PC --> Send MainCommand
BS2 --> Acknowledge receiving MainCommand, await SubCommand
PC --> Send SubCommand
BS2 --> Acknowledge receiving SubCommand, process command sequence
This is what the code looks like in VB..
VB:
SerialPort1.Write("Sending_Command1") SerialPort1.Write(Command1) Try 'Request 2nd command SerialPort1.Read(b, 0, 20) If SerialPort1.BytesToRead <> 0 Then MessageBox.Show("Got some data!") End If Catch ex As Exception End Try SerialPort1.Write("Send_Command2") SerialPort1.Write(Command2) Try 'Request 3nd command SerialPort1.Read(b, 0, 20) If SerialPort1.BytesToRead <> 0 Then MessageBox.Show("Got some data!") End If Catch ex As Exception End Try SerialPort1.Write("Send_Command3") SerialPort1.Write(Command3)I plan on going to BlueTooth, I have the AppMod Bluetooth and right now I am using port 0
