HB-25 Question — Parallax Forums
HB-25 Question
ScottishCaptainScottishCaptain Posts: 10
edited 2006-10-23 03:24 in Robotics
Greetings to all.
I've got a robot that has some hefty motors on it. They basically require 500-1A running, and draw much much more then they jam/stall.
I'm thinking about using 4 HB-25 controllers, or 2 of them with the motors paired for the left/right side in parallel.
I've got some quick questions about these units.
First- I'm assuming this is possible but I don't know as the Parallax manual doesn't explicitly state it- can you control the motor speed (or power), via sending the HB-25 a specific pulse? Something similar to PWM, so that the motor isn't full-on 100% of the time.
And second- the unit's have fans on them. Parallax's manual states the idle current draw for each HB-25, and then the current with the fan on. Does the fan itself only turn on when the control IC hits a specific temperature? Or is it on all the time?
Cheers!
-S'Captain
  • Ken GraceyKen Gracey Posts: 7,415
    edited 2006-10-22 20:05
    S'Captain:
    Greetings·rough weather sailor!
    Yes, the HB-25 receives pulses similar to servos - 1 ms is full speed CCW and 2 ms is full speed CW. That easy. With your small motors like you describe, you could put two motors on one HB-25. The HB-25s generate a servo style pulse. It's on for 1-2ms, then off for at least 20 ms. The only difference is that you need to send it only one pulse to set it (and forget it) to allow the HB-25's chip to be set a single time with a speed/direction, or you could send them over and over again if you wanted to.· The fan turns on whenever you've got power to the HB-25s - so it's on all the time.
    You could manage much larger motors with these controllers, by the way. These motors are drawing 10-20 A at 12V:
    ·attachment.php?attachmentid=43764
    Post Edited (Ken Gracey (Parallax)) : 10/22/2006 8:09:38 PM GMT
    600 x 400 - 111K
  • ScottishCaptainScottishCaptain Posts: 10
    edited 2006-10-22 21:59
    Thanks for the reply.
    When you say that 1ms is full CCW and 2ms is full CW, is it possible to set it to run at like half-CCW speeds (or power, I guess)? Would that be sending it a 0.5ms pulse for example, or a 1.5ms pulse for half-CW Speeds? (That's the only logical conclusion I can think of, since I've never played with Servo's like this before).
    The particular robot I'm building needs to be "house-trained", and as it is the platform I want to use (Lynx Motion 4WD3) runs at over 45"/second, which is a bit fast for my use as I'd hate to see it crash into a drywall at this speed. That's why I need to know if it will run slower when required to.
    Nice robot, btw. Looks like a heavy little beast!.
    -S'Captain
    edited 2006-10-23 00:33
    Sure, generate a 1.5 ms pulse to be still. On the BS2-IC, this would be PULSOUT pin, 750. There's a full range of speed control between 1.5 ms (center) and 1.0 ms (CCW) and 2.0 ms (CW). You can make your robot go slow with the HB-25s.
    - Ken
    Great. Thanks.
    That's what I needed to know.
    Cheers!
    -S'Captain
