Does anyone know who to access the code of a picture? I have some stuff on my computer and I want to look at the code for the pictures but can't figure out how to get inside the code.
There are a whole variety of picture formats including .JPG, .BMP, .TIF, .PNG, .GIF and they're all completely different. Some of them are standard like JPG and PNG. You'll just have to Google the ones you're interested in to try to find a definition of the file format.
Bean said...
When I want to get pictures into a microcontroller (for an LCD or whatever), I find that the old .BMP format is the easiest to decode.
Thanks for the tip. Can I simply save a few pictures as .BMP in Xp or do I need to do something else to save them?
How do you view the code? I haven't been able to figure that out. I have some simple experiments I want to do with pictures and colors but haven't been able to acces the code in anything.
What I want to do is take a picture of something - say a 2x4 - on a white background and then take the same 2x4 and put it on the lawn or lean it against the car and take another picture.
Then by accessing the code of the picture with the white 2x4 I want to see if I can locate the 2x4 -· by reading the code - in the second picture.
Well, first, using "code" to describe a "picture" can be very confusing. Pictures are typically not represented by any type of code (leave me alone, purists <g>). The short explanation is that pictures are nothing more than data which represents the color at a certain point in the picture...there are many ways to represent the color, either from a fixed pallette, as an absolute value, or as a comparison to a previous color. There is a glorious amount of information on this topic to be found (and it is interesting, as well).
To address what you would like to do, this type of task is usually handled by image analysis techniques using color analysis, edge detection and the like. There is also quite a bit of information about these topics available and it can rapidly run into PhD level cognations. In any case, these functions typically require a fair amount of memory and LOTS of speed.
A lot of this falls under the headings of "image processing" and "recognition" and "visual analysis". All fun topics, but not for the faint of heart.
Truly Understand the Fundamentals and the Path will be so much easier...
If you want to experiment with your idea, get yourself a hex editor, preferably with a file compare like Cygnus ( shareware ). You can open and view hex code from pictures, and do a compare to find the difference in the code. What the info really means is another issue.
It also has an export to C and asm.
Don't visit my new website...
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Don't mistake experience for intelligence. And vis-vera.
Any help with this would be most appreciated.
YOU have to write the code to read the picture. And BMP is probably the easiest format to do that.
I used DOS based Turbo Pascal to write my code. It's pretty straight forward.
I just save the pictures as 24-Bit with a certain X and Y size. Then you can just "skip" the header information and there is the pixel data.
What format do you need to get the pixel data into ?
Bean.
Wait a minute, how does the CMU manage to follow colors? It gets programed. Is it the same sort of thing?
looks like arabic.
kelvin
