Sending large variables to Pink fails. Anybody solution?
Hi everybody,
I'm having difficulties in sending large variables to my Pink module. What i am trying to do is something like this:
addr·· VAR·· byte
char·· VAR·· byte
FOR addr = 0 to 63······································· 'count 64 address positions, largest possible variable in Pink
GET addr, char··········································· ·'Read from RAM
SEROUT 15, Baud, [noparse][[/noparse]"!NB0W06:", char, CLS]····· 'output to Pink
Next
The Pink module does not accept this and seems to choke on this. It reacts like its getting a new 1-byte variable for 64 times in too short time, hence the rejections.
What is the best method in sending large variables (of 64· bytes) to the Pink module? The use of strings seems useless for they cannot be made long enough.
Best regards,
Ed.
A horse is a horse, of course of course...
addr·· VAR·· byte
char·· VAR·· byte
Next
Best regards,
Ed.
http://forums.parallax.com/showthread.php?p=556998
addr·· VAR·· byte
char·· VAR·· byte
SEROUT 15, Baud, [noparse][[/noparse]"!NB0W06:"]····· 'output to Pink
FOR addr = 0 to 62······································· 'count 63 address positions, largest possible variable in Pink
SEROUT 15, Baud, [noparse][[/noparse]char]····· 'output to Pink
Next
SEROUT 15, Baud, [noparse][[/noparse]CLS]····· 'output to Pink
regards peter
Post Edited (Peter Verkaik) : 10/16/2006 10:25:36 AM GMT
This seems a logic step and i seem to remember that i tried something familiar, but because i couldn't get it to work, i abandoned that approach. I will try your suggestion and will get back to you on that.
Secondly, i have read your thread on the rollover issue and i really could use extra space for storing variables and it seems as if there is no real boundary (ofcourse the 6300 character boundary is) so i will try that allso.
Thank you very mucht for your reply. I'm feeling confident that i will get done what i planned in the first place.
Best regards,
Ed.
I tried suggested approach and i got it to work!
Thanks again for the support.
Best regards,
Ed.
