Using Analog Comparator to read a PWM analog signal?
I have an RF Module that outputs the RSSI (Recieved signal Strength indicator) in a PWM signal.
The wave can be from 0% to 100% duty cycle.
I would like to use the 8-Bit ADC converter example to have my SX read the analog value from that PWM signal.
I have attached the circuit that I want to run.
With a PWM comparator using a PWM signal, is there potential for noise or mis-readings from a PWM signal?
Please help.
Shaun
Please help.
Shaun
PWM is already a digital signal. Why would you want to convert it to analog, then read it with an ADC ?
Just measure the on-time and off-time. Or am I missing something ???
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Don't mistake experience for intelligence. And vis-vera.
Sorry about wasting bandwidth.
Off I go to work with PULSIN
