Multiply High?
I have been looking and looking, but I can't find much info on the Multiply High command, **.· I need to take the number 0.351 (or at least 0.35) and multiply it by a variable, ENCODE.· I believe the ** operater is the only way to de this.· Could someone demonstrait using it, or point me somewhere that has a good explanation.
NerdMaster
For
Life
NerdMaster
For
Life
Like Mike says, first convert 0.351 to a binary fraction, 351/1000 = factor/65536.
factor = 65536* 351/1000 = 23003 ' solved on a calculator
then in pbasic...
result = 23003 ** encode ' same as 0.351 * encode
Tracy Allen
www.emesystems.com
Thanks Again
crgwbr
NerdMaster
For
Life
You may find this to be an exceptionally good source of information for advanced math application in the PBASIC Stamp including the ** and */ operators:
http://www.emesystems.com/BS2index.htm#math
Thanks go to Dr. Tracy Allen, the author of that web site, and Stamp Math Guru!
Bruce Bates
