Propeller with Parallax GPS Receiver Module
I'm new to the spin language and was seeking some·help with this setup/code.
I have the propeller·demo board·and the Parallax GPS Receiver Module. The 4 pins on the GPS module are GND, VCC, SIO, and RAW. Currently, I have the GND pin going to VSS on the propeller demo board, VCC going to 5V on the demo board, and SIO going to I/O pin number 0 on the board.
What I am having trouble with is sending this header value "!GPS" plus a hex value (0x00) to the SIO pin (i/o pin 0)·and then receiving the·2 bytes back on i/o pin 0.
I am using the FullDuplexSerial v1.1 for the serial communication. Here is the code I have so far.
Any help is appreciated. Thanks.
Michael
Michael
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
text : "vga_text"
serial : "FullDuplexSerial1_1"
VAR
Byte RX_value[noparse][[/noparse]2]
Byte Index
PUB start
text.start(16)
dira[noparse][[/noparse]01]~~
serial.start(1,1,0,4800)
serial.tx($21)
serial.tx($47)
serial.tx($50)
serial.tx($53)
serial.tx($00)
Index := 0
repeat 3
RX_value[noparse][[/noparse]Index++] := serial.rx
Index := 0
repeat 3
text.hex(RX_value[noparse][[/noparse]Index++],8)
text.out($0D)
This may help you.
· serial.str(@msg1)·····
· serial.tx($00)
· waitcnt(900_000+cnt)
DAT
· msg1··· byte··· "!GPS",0
I use this format to communicate with a uMMC card writer/reader.
Hope this help.
The program I use to communicate with a uMMC card writer/reader is :
'' uMMC_1.spin
CON
· _clkmode····· = xtal1 + pll16x
· _xinfreq····· = 5_000_000
· RX_PIN······· = 2
· TX_PIN······· = 3
· MODE········· = %0000································ ' see FullDuplexSerial.spin for description
· BAUD········· = 9600
VAR
······· long··· k
OBJ
······· term··· : "tv_terminal"
······· serial· : "fullduplexserial"
PUB start | i
· serial.start(RX_PIN, TX_PIN, MODE, BAUD)·········· ' initialize serial object
· waitcnt(4_000_000+cnt)
··· term.start(12)
··· term.str(@title)·
··· waitcnt(40_000_000+cnt)
[noparse][[/noparse]Main starts here]
· term.str(@msg1)
· term.out($09)····
· serial.tx(13)
· repeat until k==">"·········
··· k:=serial.rx
··· term.out(k)
DAT
· title·· byte··· "First uMMC Read/Write",13,13,0
· msg1··· byte··· "V",0
0x21 which is !
0x47 which is G
It looks like I am just getting back the command I am sending. I don't know if the GPS module is returning that or the code is reading it from memory
Post Edited (Michael Rankin) : 10/10/2006 1:47:18 PM GMT
try this following code. Note, I have removed the use of fullduplex and am using 2 code snippets courtesy of Mike Green. It works like a charm for me in my AC4790 work I am doing w my ALIBE project.
hope this works for you
Const #1, Pin_GPS Var byte buffer[noparse][[/noparse]256] Pub Main |s DirA[noparse][[/noparse]Pin_GPS]~~ repeat buffer[noparse][[/noparse]0] := "!" buffer[noparse][[/noparse]1] := "G" buffer[noparse][[/noparse]2] := "P" buffer[noparse][[/noparse]3] := "S" buffer[noparse][[/noparse]4] := $0 txData rxData PUB rxData | c, x x := 0 repeat until (c := SerialIn(Pin_GPS, 4800,1,8) ) == 0 buffer[noparse][[/noparse]x++] := c buffer[noparse][[/noparse]x] := 0 PUB txData|x x := 0 repeat until (buffer[noparse][[/noparse]x] == 0) SerialOut(Pin_GPS, buffer[noparse][[/noparse]x++], 4800, 1, 8) '// '// Code courtesy of Mike Green '// PUB serialIn(pin, Baud, mode, bits) | bitTime, time {{ Accepts asynchronous byte value on defined pin, at Baud, in mode for #bits Mode: 0 = Inverted - Normally low Constant: Inv 1 = Non-Inverted - Normally high Constant: NInv }} dira[noparse][[/noparse]pin]~ ' Set up input pin as an input bitTime := clkfreq / Baud ' Calculate bit time for Baud waitpeq(mode << pin, |< pin, 0) ' Wait for idle (should be idle) waitpne(mode << pin, |< pin, 0) ' Now wait for start of start bit time := cnt ' Wait until middle of start bit waitcnt(time += bitTime >> 1) repeat bits ' Sample input at the middle of waitcnt(time += bitTime) ' each data bit time for #bits result := ((ina[noparse][[/noparse]pin] ^ (1 - mode)) << bits | result) >> 1 '// '// Code courtesy of Mike Green '// PUB serialOut(pin, char, Baud, mode, bits ) | bitTime, time {{ Send asynchronous character (byte) on defined pin, at Baud, in Mode for #bits Mode: 0 = Inverted - Normally low Constant: Inv 1 = Non-Inverted - Normally high Constant: NInv }} outa[noparse][[/noparse]pin] := mode ' Set up output pin with the proper dira[noparse][[/noparse]pin]~~ ' idle state and as an output bitTime := clkfreq / Baud ' Calculate bit time for Baud char := ((1 << bits | char) << 1) ^ (mode == 0) ' Add start/stop bits & invert if needed time := cnt repeat bits + 2 ' Send each bit based on baud rate outa[noparse][[/noparse]Pin] := char char >>= 1 waitcnt(time += bitTime) waitcnt(time += bitTime * (bits + 2)) ' Allow a character time for pacing▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://ALIBE.crosscity.com/
http://fstop.crosscity.com/
http://icar.crosscity.com/
