Decimal to String
Hello,
Is it possible to convert a decimal (like 2348) to a string ("2348")·without using an IF THEN ELSEIF command.· I have numbers (coming from an encoder) that I need to display on an LCD,· LCD's only display strings.· Thanks.
NerdMaster
For
Life
NerdMaster
For
Life
example:
30 + 0 = 30 = ASCII '0'
30 + 1 = 31 = ASCII '1'
etc.
Rodney
Just to clarify Rodney's answer that would be hex 30 or decimal 48.
BTW, I'm starting to give my age in hex as people don't seem to question the $ [noparse]:o[/noparse])
Rodney
Heck I'm only $27 years old...
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Don't mistake experience for intelligence. And vis-vera.
That would help a lot, only problem is I have a range of·decimals -2500 through 2500 that I need to convert to the·same number, only in string format instead of decimal.· I'm probable going to switch this project to·a BS2.· I'm more familliar with PBASIC that SX/B.· But if anyone knows how to do this in SX/B, please speak up.
Thanks a lot.
NerdMaster
For
Life
' ----------------------------------------------------------------------------- ' Use: TX_DEC3 value aByte ' -- displays value in Decimal format (text), Does not supress leading Zero's ' -- TX_DEC3: temp2 = __PARAM1 ' copy output value temp2 = temp2 / 100 ' get 100's digit temp3 = __REMAINDER ' save 10's & 1's temp1 = "0" + temp2 ' make 100's character TX_BYTE temp1 ' print it temp2 = temp3 / 10 ' get 10's digit temp3 = __REMAINDER ' save 1's temp1 = "0" + temp2 ' make 10's character TX_BYTE temp1 ' print it temp1 = "0" + temp3 ' make 1's character TX_BYTE temp1 ' print it RETURN ' return to caller
Post Edited (Mike Cook) : 10/10/2006 12:26:39 PM GMT
As soon as I get my serial cable back from my dad, I'll try that. It doesn't look like it will be to difficult to modify for 4 digits. Thanks Again.
NerdMaster
For
Life
Probably the best fit is this one:
http://www.sxlist.com/techref/ubicom/lib/math/radix/b2a-16b5a-rl_sx.htm which is 16 bits in and 5 digits out.
James Newton, Host of SXList.com
james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
Post Edited (James Newton) : 10/10/2006 6:49:08 PM GMT
TX_DEC3 150
correct?
NerdMaster
For
Life
idx = 150
TX_DEC3 idx
Also to use the SUB you will need to define it, take a look at the attached file.
