Conductive silver tracing and epoxy
I haven't seen anyone post about this yet, so after a simple test to make a small circuit, it does work. Adheres well to fr4 and negligable resistance through traces. Components can be epoxied right to the board or through holes. Must have patience to work with it. Heat curing will produce a working circuit in less than a half hour. It is normally used to repair circuits, but thought it would be worth playing around with.
kelvin
kelvin
I would like to use it to connect vias on double sided board. Have you tried that ?
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Don't mistake experience for intelligence. And vis-vera.
Here is some one who carries the pen (quick Google search)
http://www.wassco.com/chemcirworpe.html
Keep in mind, that once the epoxy dries, it becomes very brittle, ...and don't expect to push a lot of current through
your "wires" either.
Beau Schwabe
IC Layout Engineer
Catalog #: 64-4339
There's nothing a good wack with a hammer won't fix
Darn I let the white smoke out again
Bean, i made a via with the pen and it looks okay. The trace solution seems to bond well to the fr4. But, at this point, i couldn't guarantee it is the type of thing you would want to use.
kelvin
We all know that the pen is expensive because it contains a lot of silver. But you should also be aware of the 'Use by' date on it. I think it's about 6months or so. And it may be a lot shorter if the shop doesn't sell too many of them...
Don't visit my new website...
kelvin
I think the expiration date was on the packaging, though...
(Who remembers to keep that?)
I found a bottle of stuff called Wire Glue and I will try that out.
Small viles of conductive copper paint maybe sold at DIY auto parts shops for fixing rear mirror defrost conductor traces.
All similar products I've tried tend to go bad fast.
If fine copper wool and filings could be tinned and mixed with a flux glue that sets with a soldering iron I think that might work nice.
THIS INVENTION IS DONATED TO PUBLIC DOMAIN.
CC1onUVNET
"No good deed goes unpunished."
There are a couple of other options, high solids paints (I've worked with 98% "zink rich"), some tins and tin based compounds and the silver based products you discuss above. Here is a company thet make paints that can be used to screen print a PCB
http://spraylat.com/gentextlong.asp?miKey=189
Interesting hey
By the way (as an after thought hence the edit). Some of there compounds can be a bit toxic.
John Bond
kelvin
How many connections?· For small applications, the Conductive silver Epoxy would work just fine.
You can use Silver-solder to solder to aluminum, but it takes more heat than a regular soldering iron (<- Butane torch) and there is
a trick involved... to get a good solder flow, both materials should be right at or just below the point of glowing red.
Beau Schwabe
IC Layout Engineer
http://www.lpkf.com/products/rapid-pcb-prototyping/through-hole-plating/proconduct/index.htm
kelvin
