switch a 2amp load with a 555 timer
I want to switch a 2amp load with a 555 timer.·· Using one transistor I have a base current of aprox 200 ma. At 12 volts this is 2 watt. Can the 555 handle 2 watts? I know it can handle the 200 ma.
····· Even if I use two transistors( is this connection correctly called a darlington pair) with one transistor switching the base for the next transistor, I still·· waste· 2 watts.·· Would a mosfet be more efficient? ie less gate current.
Post Edited By Moderator (Chris Savage (Parallax)) : 10/6/2006 7:50:02 PM GMT
Chris Savage
Parallax Tech Support
Yes and nano current to drive it.
Think outside the BOX!
Post Edited (Mike Green) : 10/7/2006 5:03:40 AM GMT
