A question about cogs
I want a cog to do nothing but take Sonar Readings.
I read the sonar with a Pulsin command from the BS2 Library.
Anyhow... In my Object I have a "Start" method that just starts the cog with a user defined pin number. Then I have a public "Read" method that is a loop that does nothing but take readings.
The "Read" method doesn't return anything because it is in a loop constantly taking readings.
What simple thing am I missing here
Here is the Code for the Sonar Object.
My question is how to get·the "Result" from The Pub Read back to the·main program?
Hope this makes sense.
Eric
Con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
Var
Long Stack[noparse][[/noparse]25]
Long Cog
Pub Start(Pin)
Cog:=Cognew(Read(Pin),@Stack)
Pub Read(Pin):R
Ctra := 0
Ctra := (%11010 << 26 ) | (%001 << 23) | (0 << 9) | (PIN)
Repeat
DirA[noparse][[/noparse]PIN]~
frqa := 1
waitpne(1 << pin, |< Pin, 0)
phsa:=0
waitpeq(1 << pin, |< Pin, 0)
R:=(PHSA/ (clkfreq / 1_000_000) + 1)/147 ' Calculate Inches from the Pulse Width
Eric
