Is Goldbergian a word?
Another external difficulty.· I need to convert 8-bit binary to a proportional freq.· 00000000 = 0Hz and 01100100 = 1000Hz approx.· I suppose that I could feed the 8-bit to a D/A and the resulting V to a VFC, but that seems clumsy.· Is there a more elegant solution?
I'll just steer you toward a little something called --·FREQOUT.
FREQOUT Pin, Duration, Freq1
Freq1 can be a variable, constant, or expression.
In your example, you want 1000 Hz when x = $64 [noparse][[/noparse]and that's 100, decimal.]· If you multiply x by 10 then it's 1000 and you can figure out the rest (can't you?)
Hint: x = Freq1
Post Edit -- "Goldbergian".· I suppose.· Victorian, Edwardian, Hitlerian.· Why not Goldbergian?· Can you use it in a sentence?
Post Edited (PJ Allen) : 10/6/2006 2:09:55 AM GMT
