DS1620 High Resolution temperature reading - FYI
Beau Schwabe
I thought I would pass this information along...
The HiRes Formula...
Temperature = Temp_read - .25 + (Count_PER_C - Count_Remain) / Count_PER_C
...would still apply, but you could simplify it a bit to...
Temperature = Temp_read·+ .75·- (Count_Remain * .0625)
Temperature = Temp_read·- .25 + (16 - Count_Remain) /·16
...Either way, you would eliminate the need to read the value for Count_PER_C in your program.
Email correspondence below
Hello Beau,
You are correct that the·read slope command always returns a value of 16.· The original DS1620 was based on a dual oscillator·design.· The new version uses a bandgap reference, and therefore the·count per c is fixed at 16.· ·It will remain fixed at 16.· I also agree that 1/16 = yields a resolution of .0625.
Thermal Applications Support
Dallas Semiconductor/MAXIM
Original Message
From: bschwabe@parallax.com [noparse][[/noparse]mailto:bschwabe@parallax.com]
Sent: Tuesday, October 03, 2006 8:04 AM
To: Thermal.Support@dalsemi.com
Subject: Tech Support: DS1620 (TS) [noparse][[/noparse]Parallax Inc.]
======================================================================MAXIM TECHNICAL SUPPORT REQUESTDate: 2006-10-03 08:03:53IP : XX.XX.XX.XX======================================================================CONTACT INFORMATION
Email Address: bschwabe@parallax.comFirst Name : BeauLast Name : SchwabeJob Title : IC layout EngineerCompany : Parallax Inc.Division : Address1 : Address2 : City : State : Postal Code : Country : UNITED STATESPhone Number : ##############Fax Number : Dist Center : Maxim USAExport Info : No RestrictionsRELATED PRODUCTS AND APPLICATIONS / CUSTOMER IMPACT
Part Numbers : DS1620Application : Demonstration application for our customersAnnual Usage : Product Line : Temperature SensorsProduct Ln Id: 11PROBLEM DESCRIPTION
Hello,I haven't been able to find this in the datasheet or I have simply overlooked it one of the two.
Can someone confirm for High resolution temperature readings from the DS1620, that the Read Slope
command or the "number of counts per degree C" always seems to read a value of 16 when I look at it?
This would indicate a resolution granularity of 0.0625 per deg C (0.1125 per Deg F)
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/4/2006 9:03:41 PM GMT
Hello Beau,
Original Message
Does the "16" value that I am reading seem correct?·
Is this value subject to change by process variation or is it a fixed constant?
Thank you
Thank you
Beau Schwabe
IC Layout Engineer
Thanks.
John
Manxstamp,
Isle of Man, British Isles
I tried to look on my DS1620 for any hints i.e. RevB letter etc. but the print was so faint it was hard to read if anything was there.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2735
On the above sight, based on the "Recommended Upgrades for New Designs" header at the top, my guess is that the "new" DS1620 version has been out awhile.
You could always call or send an E-mail to maxim to find out for sure.
Beau Schwabe
IC Layout Engineer
I don't mean to hijack your thread, but have you ever checked out the DS1848 from Maxim (about $5 from Newark).
The DS1847 is the same but minus the 128 bytes of EEPROM.(about $4 from Newark).
The DS1858 is the same as the DS1848 but also has a 3 channel 12bit ADC.
It is I2C and has a 13bit (1/16'C) temp sensor, two digital variable resistors (single ended, not pots), AND EEPROM (128+72+72) Bytes.
This IC is used to compensate a circuit for temperature changes. You program the EEPROM, and the chip will adjust the two resistor values for every 2'C from -40 to +95.
It's a really cool chip that I use at work.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Don't mistake experience for intelligence. And vis-vera.
Post Edited (Bean (Hitt Consulting)) : 10/4/2006 9:43:07 PM GMT
"...have you ever checked out the DS1848 from Maxim...", no I haven't.·
This thread was basically started, because of something I happened across when writing a Propeller object
for it.· Since the DS1620 is something that we sell at Parallax making an object for it made sense.· There
are certainly other alternatives in which IC to use or which is the best fit for a particular application.
I do like the idea of having some scratch pad EEPROM available in an application as well.· The temp comp
pots add a nice touch also.· I might look into this and see.
Thanks Bean!
Beau Schwabe
IC Layout Engineer
How about showing us the code! Really interested in its sensitivity!
Guido
The configuration "2" is the parameter that follows the actual command, "12" 12 is the configure command
2 is the particular configuration, "continuous conversion with CPU"
I'm attaching the original change notice that came from Dallas/Maxim. The transition occured late 2002 to mid 2003. The new parts are supposed to have a date code that ends in "E2". e.g.
0437E2 where 0437 is the 37th week of 2004. The change notice doesn't mention the change in count_per_C, but I'm pretty sure it happened at the same time. Before that, the count_per_C was a temperature dependent value greater than 100 that you had to read out in order to calc the higher resolution, but in the revision they fixed that number at 16. You can find out for sure on a given chip by reading the register and if it is 16, you have the revised chip.
