External Servo Power
hi dudes,
im using the board of education (BOE) to control 4 servos, but powering the servos eat up too much battery power,
so i tried to power the servo using a Futaba receiver (model R1490P), and i snipped the white wire and plugged the
white wire at P15.
the servo does have the correct response when its plugged into the servo port (15) on the BOE, but not when the black
and white are in the receiver and the white at P15. any idea why this is happening?
(ps it does work when all 3 are plugged into the receiver, but the signal i want should come from P15)
white wire at P15.
The grounds need to be common for a setup like that to work correctly.
Bruce Bates
<!--StartFragment -->
This is referred to as having a "common ground" and shows up in these forums quite a bit.
Truly Understand the Fundamentals and the Path will be so much easier...
searched for common ground but couldnt get any results.
my white (signal) is in P15, my black is at VSS, and my red is connected
to the receiver, but i'm still not getting any results (other than the click-click
sound from the servo, which i also get when all the servo wires are plugged
into the BOE's servo slots and the BOE is set at 1 (no power to servo))
do i need to parallel my ground to the receiver as well?
my electronics knowledge is quite inadequate, would you mind explaining
how having a red wire in the receiver and the black in a BOE would allow
power from the receiver battery to go to the BOE? i thought a circuit had
had to be looped around to the same battery? (also, since VSS isnt really
'grounded', wouldnt all the spent current by the servo go to the battery?)
You asked: Do I need to parallel my ground to the receiver as well?
The answer is YES, and that's what provides the "common ground"!
Bruce Bates
not having a parallel circuit to it. will try!
it works the way it does? ie how common grounding would help the servo
to have a reference. i have a rough idea how a servo works, but didnt
know it needed a ground reference point (i thought 0v was 0v haha)
I'll let you answer your own question, by providing the following questions about your project:
Who "owns" and provides the POWER for the servo(s)?
Which part of this project supplies the SIGNAL to the servo?
Who "owns" the SIGNAL line?
When the SIGNAL comes from one source and the POWER comes from another, there must be a method to ensure that BOTH elements are using the same zero reference (aka common ground), since once they do, all other voltages, signals, etc. will naturally fall iinto place. Does that make more sense now?
Bruce Bates
That is a VERY invalid presumption. In electrical terms, "COMMON" ONLY means that generally, more than one wire is conected to it, or the terminal is connected to more than one wire, or it (the COMMON item) is a part of more than one circuit. A typical example would be a single pole double throw (SPDT) switch. Often the connection markings may read as follows:
circuit 1 common circuit 2
There is NO ground on an ordinary SPDT switch, thus that proves your presumtion is invalid. In this example the COMMON is a COMMON POSITIVE connection. Thus, COMMON GROUND is just that, COMMON POSITIVE is just that, and COMMON anything-else is just that. The text of the data sheet or documentation should indicate how or why it is "COMMON".
Bruce Bates
Post Edited (Bruce Bates) : 10/5/2006 5:04:46 PM GMT
