Strings manipulation
I need help from someone.
I think it is something very simple but I have my head hitting the walls.
I need to convert keyboard characters into strings and concatenate them.
For instance, if I type 1,2,3,4,5 and want to have a string "12345"
OBJ key : "keyboard" VAR byte buffer[noparse][[/noparse]32] PUB mainProgram | stopChar '' Example of call: stopChar := getNumber(@buffer,32) PUB getNumber(ptr, size) | c '' This takes a series of digits from the keyboard '' and returns the first non-digit character received. '' The characters are returned as a zero-terminated '' string whose address is supplied in ptr and whose '' maximum size is supplied in size. repeat (c := key.getKey) case c "0".."9": if size > 1 byte[noparse][[/noparse]ptr++] := c size-- other: byte[noparse][[/noparse]ptr] := 0 return cI am going to try it.
