433 mhz modules
I have been messing with the modules I bought for parallax, and I still have no luck getting them to work. I got the code from the datasheet, which is attached below, all help is greatly appreciated. I am really new to electronics, and robotics
You are programming the TX code on on board, then switching to another board for RX and monitoring that one?
-Martin
Martin Hebel
Personal Links with plenty of BASIC Stamp info
StampPlot - Graphical Data Acquisition and Control
AppBee - XBee ZigBee / IEEE 802.15.4 Adapters & Devices
gnd, into last slot of Vss
+5V into first slot of Vdd
p8 into data pin of transmitter
and a usb board of education (receive)with a BS2p wiring as follows:
p0 470ohm resitor to an Led going to last slot of Vss
p8 into data pin of receiver
gnd into second to last slot of Vss
With the BS2p you need to change the baud rate to 16624 since it runs at a different speed.
You probably won't be able to get 9600 baud from these units, they cannot support that baud rate. I'd suggest going to the help files and use the values for SERIN and SEROUT for 1200 baud inverted
Bs2: 17197
Bs2p: 18447
-Martin
Martin Hebel
Was the problem that the value was incorrect for the BS2p or that the 9600 was too high on both? I have been getting 9600 to work with those units with no problems.
Martin, what would it look like if they weren't performing at that speed? Lost data?
Carlos
Sorry,
Martin
Martin Hebel
Post Edited (bboy8012) : 10/1/2006 4:45:33 PM GMT
