BS2px on BOEusb and PSC connection problem
Allan,
I started a new thread regard the connection between BOEusb with PSC. I got reply from Chris that baud rate have to change as difference between BS2 and BS2px. I'll try and if you have any good suggestion, please do teach me. I found the PSC green LED only flashing without reply on debug window.
My project actually·is to connect·a·PSC to a computer via Bluetooth. So, I have BOEusb w/BS2px, a PSC, a eb500-ser and a bluetooth adapter which support Bluetooth Serial Port.
Thks
Ricky·
Thks
Ricky·
Here's the standard code for baud rates. When you want to use a given baud, use the constant, rather than an actual number:
' Baud rates #SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 TMidi CON 12 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 TMidi CON 60 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 TMidi CON 108 T38K4 CON 84 #ENDSELECT SevenBit CON $2000 Inverted CON $4000 Open CON $8000So in your code, if you want to use the PSC's higher baud rade, use "T38K4" in your SEROUT commands. The actual value of "T38K4" will depend on the actual stamp downloaded to, but you won't have to change your code for different stamps. See the Pbasic manual for more info about conditional compilation and see the SEROUT command reference for the table that shows the different "units" used by each stamp for baud rates and the like. Does this help?
Ricky
thks,
ricky
·· Assuming this is a USB PSC, then you have to have the USB Driver installed before you can talk to it from the PSCI software.· The driver will assign a COM Port number to the device, and this is the one you need to use in the PSCI software when opening the port for it.· If you’re on a laptop you may or may not need to reduce the latency timer setting in the Advanced Port Settings in the Device Manager.
Chris Savage
Parallax Tech Support
ricky
Thks
Ricky
Chris Savage
Ricky
·· My best advice is that if you really intend PC control then you should get the USB version of the PSC which will connect directly to PC and allow you to directly use the PSCI software.
Chris Savage
·· There is no file to save…You will need to copy the values from the PSCI Software into DATA statements in your code and play them back that way.· I have no other new suggestions.
Chris Savage
One could stuff the commands in an external EEPROM for more portability, if that's helpful.
Bruce Bates
<!--StartFragment -->
http://forums.parallax.com/showthread.php?p=611904
Chris Savage
I have changed my board to SSC-32 with a Wiport Wi-Fi and·they work fine. I can now control my robot without a wire in between that you can not support in this area. Once I finish my project, I'll study your suggestion.
rgds,
Ricky
