Query (ergo help!)
Having a great time learning to program my BSP40 chip. I have 3 slots in use.
In two slots I setup a serial keypad, serial LCD and serial memkey. I then input my data. The data items are stored in RAM.
I then go to another slot to execute all the stuff, pulling out data items from RAM as needed.
All this works fine BUT--
The keypad has a couple of keys that I want to use from within in the final slot. Such as ABORT etc.
How can I execute a key from the keypad after I move out of the slot that has the GetKey routine?
Hints greatly appreciated and I will almost definitely mention you in my will.
Austin
Austin
There is a lot of that around this forun ya know. I'm still working on "pick a card, any card"
