"Ping" device - does it or does it
guys,
Can someone who's using tjhe ping device confirm or correct to me please.
When the Ping device is hooked up to suppose your prop, do you see it making "chirp" sounds especially, when you have a 1 sec pause btwn each method calls to ::Inches ::Millimeters ??
I was told by the Parallax tech support that one should not be able to hear anything due to the high freq nature of the sound. I however experienced otherwise from my experience w/ SRF08 and was later on told by one of my buddies who's using Ping that he does in fact hear feable chirp sound.
Have I lost my mind.
thanks, ALIBE
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://fstop.crosscity.com/
http://icar.crosscity.com/
thanks, ALIBE
I'm no scientist or ultrasonic expert, but I often hear a "click" from the Ping))) when I listen carefully. The clicks increase with the proximity to the object under measurement. The Ping))) firmware takes more measurements as the object nears the module. Perhaps this is the ultrasonic sound starting and stopping.
I work in a television production room and I hear the 15.7Khz like clear day.
It starts to drive people here up a wall when you get 6 NTSC monitors running at once all generating that high frequancy tone.
I'm using da Ping wid da Prop, OK!
And To tell you the truth, I did not hear anything until reading your post in this thread.
what I hear is a clicking sound @ 3 to 4 clicks /sec. the sound is very faint.·to hear it·I must place my ear right up to the Ultrasonic transducers.
So, I guess that, when I do this, I am·speeding up clicks by placing my head closer to the sensor.
But I got to let you know that, @ no time do I hear any ultrasonic sound/s. all so it does not seem to be bothering the cat.
so it can't be to bad!
I guess, Maybe you should·get your hearing tested. Maybe an audiologist can tell you why you hear it when others don't.·
good luck
IAI (Indigenous Alien Intelligence),
The New View on Machine Intelligence.
Because There is nothing Artificial about it!
I also used to hear when I was a kid when my mother left the electric stove on. I could hear what I assume was a relay cycling the burner on and off.
Brian
Tracy Allen
www.emesystems.com
Ken, Tracy;
it makes sense as I read your explanation.
·· I was the Tech you spoke with.· What I said was that you cannot hear the 40 KHz pulses that the transducer is sending.· You used the term, "chirp", which to me sort of implies a high frequency noise.· In fact there is a very faint click sound coming from the PING))) when it is emitting the pulses, but that click is nowhere near the 40 KHz range, which you cannot hear.· As Ken and Tracy pointed out there is noise generated during the creation of the pulse which could also be compared to distortion in audio speakers.· I had explained this to you when you mentioned the SRF module making that noise.· Again, I just wanted to be clear that the click is nothing more than noise and is not the actual 40 KHz pulse, as it is possible to hear the click regardless of the frequency being emitted.· I hope this clarifies my earlier comments.· Take care.
Chris Savage
Parallax Tech Support
