Interrupt vs If then
I am trying to learn about interrupts and have a simple application that needs either an inerrupt or and if then to halt an activity temporarily.
Here is the idea, leaving out parts of code:
SIO VAR RA.0 'receive pin
UP VAR RA.1 'motor driver inut up direction
DN VAR RA.2 'motor driver input down direction
PW VAR RA.3 'pwm out to low side of motor
serByte VAR Byte
RX_Byte SUB 0
ON CON 0
OFF CON 1
Main:
serByte = RX_byte
IF serByte = %00000001 THEN
UP = ON
PWM PW, 150, 50
UP = OFF
ENDIF
IF serByte = %00000011 THEN
DN = ON
PWM PW, 150, 50
DN = OFF
ENDIF
Goto main
This code looks for a byte from a remote control that transmits a byte in a fast loop while a button is pressed. While the button is pressed, the motor turns uninterrupted. That part is working great.
I need to add some lines in the event of a stall to prevent smoking parts. If I can make room on the board I'll add a sense circuit with logic back to the SX. In this case, would an interrupt be a better option that IF THEN for halting the output to the motors? The only other idea I can think of is IF SensePin = 1, SensePauseLoop (go to a routine, turn off motor, wait for a few seconds before returining to look for more bytes. I figure if the user notices that the thing isn't moving, they will stop presing the but rather quickly, and the pause loop will avoid the motor driver getting hot.
I am studying the 3 interrupt programs that come with the SX Key. I am stil not clear on how to set this up to look for an interrup on a pin, but will the interrupt function the same way as IF THEN on a pin?
Post Edited (originator99) : 9/24/2006 5:12:27 AM GMT
serByte VAR Byte
RX_Byte SUB 0
ON CON 0
OFF CON 1
Main:
serByte = RX_byte
UP = ON
PWM PW, 150, 50
UP = OFF
ENDIF
DN = ON
PWM PW, 150, 50
DN = OFF
ENDIF
Goto main
Also the SX/B (and the BS2) PWM command is not meant for motor control. This is because it is not a single pulse for each duration. It is a series of pulses designed to be converted to an analog voltage.
If you are using the SX48 your best bet would be to use the hardware timers to generate the PWM. Then it WILL be appropiate for a motor controller. Plus to can "set it and forget it" because the hardware timers operate on their own.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
I am still looking for the smallest possible solution to get a logic 1 off of the sense R. I can't fit any more chips.
