SX/B vs. SASM vs. Parallax Assembly Language: A Newbie Question
I'm going to be purchasing an SX-key programming kit (I've programmed Stamps, 808xx controllers in assembly, etc).
I've been reading through the available docs and web pages, and there is something I'm not clear on, so I wanted to make sure I have it straight.
SASM = current assembly language for the SX-key compiler
SX/B = Pbasic -like language that compiles to assembly in the SX-key IDE
Parallax Assembly Language = an old, legacy assembly language
Do I have that right? If I don't, let me know. If that's basically right, I have three questions --
- There is a newer (beta?) version of SX/B at the forums. Mr. Hitt posts these -- is this Mr. Hitt's software or Parallax's? Kudos either way, but I'm curious.
- SX pages at the main site have some things along the line of this:
So if I see Parallax Assembly Language in code or docs, should I figure that it's "legacy" code and compile it that way?
- If I drop into assembly language from within an SX/B program I'm presuming current IDE will use SASM?
Any other clarifications on the three languages??
Somebody said...
Now available for download with SX/B Examples! Al Williams' popular Exploring the SX Microcontroller with Assembly and BASIC Programming was released this week as a free web download. All examples are shown with the SX/B and Parallax assembly language. The
The latest SX/B version will aways be available on the SX/B forum (currently 1.51.02). SX/B produces SASM code only.
The great thing about SX/B is you can see the assembly code that it generates and this allows you to learn SX assembly quite easily.
Also mixing assembly within SX/B is very easy.
SX/B is a parallax product. I currently do support and updates to the compiler. If you find any bugs (or think it's a bug) please let me know on the forums.
Do you have any projects in mind for the SX ?
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
And, oh boy, I've got projects in mind! When I realized how cheap and cool the SX is, I realized it's time to dive in. My first few projects will be offloading some functions from the BS2p40 that runs my 'bot (motor encoding, sensor data), plus a few gizmo-type Holiday Gifts (sensor-activiated LED displays) that would be prohibitively expensive with Stamps. And to be honest, I really enjoy the clarity and timing control of assembly sometimes -- a level you can't really drill down to on the Stamp.
SX48 http://www.parallax.com/detail.asp?product_id=45300
SX28 http://www.parallax.com/detail.asp?product_id=45302
Bean.
What's the difference between a resonator, a crystal, and a TTL clock? I get the physical differences, just not which you would use and when.
