A quick surface mount adapter
Graham Stabler
This is something I did recently when I wanted to breadboard some surface mount chips without firing up my mill or etch tank.
Take some multi-core hook up wire and remove a few strands of wire. Tin and then solder these carefully to the legs of the surface mount device. Fill the sockets of a DIL chip socket with solder, solder the chip in place and trim the wires. Add a label if you want.
Not original I'm sure but with some much stuff in SMT format these days I thought someone might find it useful.
Graham
p.s. I soldered my chip in the wrong way around (doh!) but the label makes it OK
Graham
- Rick
Graham
Paul Baker
That with bugs [noparse]:)[/noparse]
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
Did you see the research on Egyptian Cataglyph ants, where the researcher was interested in how they measured the distance to their nest? They find the direction by the sun, but apparently they count strides to measure distance. The researcher fount that ants with stilts glued to each leg overshot the nest proprotionally.
Tracy Allen
www.emesystems.com
The only dead bugs I've ever seen are under my desk! (j/k)
But no really, I always used what they call Surfboards. They're small surface mount breadboards that map all pins to something with a DIP spacing. They are more costly, but very clean in the end.
--Andrew Arsenault
Don't visit my new website...
Back in 1983, my mother bought me one of these puppies - she got us the ""Sinclair ZX Spectrum +" (the larger kind).
I started my computer geek career w/ it programming away w/ ROM-BASIC - and after so many years, I still have that in my office - framed up.
I love that home computer.
Nagi
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://fstop.crosscity.com/
http://icar.crosscity.com/
http://forums.parallax.com/showthread.php?p=464494
Chris Savage
Parallax Tech Support
With the talent at Parallax, it could even be 3 years......
That's true. Who knows what crazy propeller chips they'll have in 3 years.
It would be like comparing the Basic Stamp to the Basic Stamp II.
