Controlling Darlington with SX...
I am seeing issues controlling my darlington transistor with an SX.
I want to be able to provide source current to pin1 of the connector.
The Transistor is a ZTX603...My base resistor is 370 ohms, and my Collector resistor is 1k.· Should I swap both of these resistors with 10k?
Thanks.
Shaun
Post Edited (Steel) : 9/20/2006 5:49:10 PM GMT
Thanks.
Shaun
· The only thing in your circuit connected to Vcc is the 1K resistor. So that is the only path to "source" current to the connector.
· What exactly does the connector connection require to·operate ?
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Paul Baker
I know that the SX pin will not provide enough current for the solenoid, so I am putting in a darlington transistor in circuit to provide current from the source voltage.
My goal was:
When the SX Pin is high, no current is flowing to the connector at the collector.
When the SX Pin is Low, the source voltage (5V) is flowing to the collector at the connector.
When I measure the voltage on the SX pin, it is correct 0 or 5V.
When I measure the voltage on pin1 of the resistor, it is correct (based on what the SX pin is saying)
When I measure the voltage on Pin2 of the resistor, or anywhere beyond the Transistor, I am reading about 2V.
I think the Transistor may be blown, and I want to replace it, but I want to make sure I have the correct resistor values/theories behind it to prevent it from blowing again.
Shaun
According to the spec sheet, the ZTX603 has a current gain of 2000 at it's maximum collector current of 1 amp. A collector current of 1 amp would require only 500 micro-amps of base current at a gain of 2000. The base voltage is 1.8 volts, and if the SX is running at 5 volts the base resistor would be 6.4 K-ohms. I would use a lower resistor value in the range of 1K to 3.3K to ensure that the Darlington is fully on.
Even though the Darlington has a high gain, I believe that you can't drive the emitter to ground. This is because the collector of the first transtor has to ride at the voltage of the base of the second transistor, which must be around 0.9 volts. If the emitter drops below 0.9 volts the first transitor will turn off.
You should connect one end of the solenoid to 5 volts and the other end to the emitter. You may need a limiting resistor in series to ensure that you don't drive too much current through the solenoid coil. What's the resistance of the solenoid coil, and how much current does it need to operate?
Dave
Dave
What are the specs on the solenoid you are trying to drive? What is the driving voltage (voltage required to operate), the driving current and its resistance (which can be measured by using an ohmmeter across it's terminals)?
Paul Baker
Here is a FAQ that might help... Don't get HOT choosing the wrong transistor
Even though it references a motor in the schematic, a Relay, Light bulb, Solenoid, etc. could just as easily be substituted.
Note: Because your transistor is a Darlington and the B-E saturation voltage is 1.8· ... use·1.8V in place of the 0.6V in the formulas above.
Beau Schwabe
IC Layout Engineer
