adapt a PINK to a wireless connection? — Parallax Forums
lmoliverlmoliver Posts: 5
edited 2006-12-28 14:09 in General Discussion
Hi,
Somebody knows the way to adapt a module PINK to a wireless connection? I have seen in the market some· Ethernet to wifi adapters, bridges and similars. It really work with the PINK? Somebody has verified it?
I try to follow the following scheme:
BOE+PINK+(ADAPTER)· --> ROUTER WIFI
Lorenzo M. Oliver
lmoliver@teleline.es
Post Edited By Moderator (Chris Savage (Parallax)) : 9/20/2006 3:43:33 PM GMT
    edited 2006-09-20 16:16
    SMC makes an Ethernet wireless adapter (SMC2671W) which works well. I've only tried it with a small single board PC, but it should work with the PINK since it's a general purpose Ethernet to WiFi bridge.
  • lmoliverlmoliver Posts: 5
    edited 2006-09-20 16:31
    If, already I have been reviewing that adapter, but in Spain it is market-out.
    That so the ASUS WL-330Gg·?
    http://usa.asus.com/products4.aspx?modelmenu=1&model=59&l1=12&l2=41&l3=0
    It seems compatible and small. Somebody has used it?
    Lorenzo M. Oliver
    edited 2006-12-22 11:47
    Thanks Mike!
    There is an example in http://www.todomicrostamp.com/interactivo13.php
    It's phase 3 of a project·that uses a BS2+PINK for wireless communications (wifi).
    Lorenzo M. Oliver
  • mike101videomike101video Posts: 43
    I'm using PINK with a Propeller and IP9100 video server, to allow the propeller to controll pan/tilt/zoom on a video camera, and IP9100 to allow the video to go over the web. To make this WiFi, I'm using a cheap wireless router ( eHome for $1.99 - after rebates from CompUSA ). PINK and IP9100 pulg into the router and then PC connects to the hub (Uses a different channel and SSID than the regular network that I use for Internet and local networking.) Seems the wring way round, ( router as the remote) but works well. (Got the idea from a robot design I saw, with the router mounted on the Bot.) Will publish some pictures when completed.
