Math with my SX?
Hey guys,
well i have a chip that i am interfacing to that gives me some variables an then i have to do some math with these values.· Can i do these functions internally with the SX.· Examples of structure would be greatly appreciated.
1.· Temp = 200+dT*(C2+50)/2^10············C2 and dT·are·know values and we are solving for Temp
2.· OFF = C2*4+((C4-512)*dT)/2^12··········C1 and·C3 are both know and we are solving for OFF
3.· SENS = C1+(C3*dT)/2^10+24576········ Again C1,C3 , and dT are known
4.· X = (SENS*D1-7168))/2^14-OFF
5.· P=X*10/2^5+250*10
6. dT=D2-UT1
7. UT1=8*C5+20224
Thanks in advance for all your help
It's Only A Stupid Question If You Have Not Googled It First!!
Post Edited (altitudeap) : 9/18/2006 6:20:31 PM GMT
6. dT=D2-UT1
7. UT1=8*C5+20224
If you want to work dfirectly in assembly, go to this page:
www.sxlist.com/techref/expeval2.asp
It will take your math expression and convert it to code. It uses various functions that are accessible from this page:
www.sxlist.com/techref/ubicom/lib/math/basic.htm
I recommend starting with some simple examples (such as are on the first page) to get a handle on the way the code is written. It's a little more like the intermediate output of a compiler, but it's not too hard once you work with it a bit. OF course, you can also just directly use the math functions yourself to do the work.
I imagine this can also be handled with SX/B, but I'll leave that to those fluent in that language.
Thanks, PeterM
Can you give us the range of each variable (F, dT, A, B, C, D, temp) ?
Or some example values for them ?
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Here we go.
Min typ. max
C1 17250 24285 30950
C2 600 1384 3350
C3 500 745 810
C4 200 405 1023
C5 0 932 1650
C6 10 28 63
D1 0 17000 40000
D2 0 22500 45000
Okay, so which one is A, B, C, D, dT, and F ?
Bean.
I am learning SX/B and really do not understand C or C++ which is what this example is that i got from the pdf for the device that i am trying to use. I would like to recieve some help as to how to write it in SX/B
Calc
Void calcPT1234 (double *pressure, double *temperature, long d1_arg, long d2_arg)
double dt, off, sens;
double fd1, fd2, x;
d1_arg = d1_arg & 0xFFFF;
d2_arg = d2_arg & 0xFFFF;
fd1 = (double) d1_arg;
fd2 = (double) d2_arg;
dt = fd2 - ((8.0 * fc) + 20224.0);
off = fc * 4.0 + ((( fc - 512) * dt ) / 4096);
sens = 24576 + fc + 99 fc * dt) / 1024);
x = (( sens * (fd1 - 7168)) / 16384) - off;
if (pressure!=0)
* pressure = 250 + x / 32;
if (temperature!=0)
* temperature = 20 + (( dt * ( fc[noparse][[/noparse]6] + 50)) / 10240
