Vga_demo??
I was just given a little 10.5" VGA monitor so thought would try it out. VGA_text_demo works fine but VGA_DEMO does not. I have tried that program before and had no problem, perhaps its just the monitor? Looking through the code however there seems to be lines commented out as if someone has been playing with it, and that is a freshly downloaded version.
Any ideas?
Graham
Any ideas?
Graham
*Peter*
I don't think it would even load without vga.spin
Graham
I think you have the same problem I have (8 inch, 640x480 only VGA).
The program published above give me a error msg "Over Range".
This have to do with the fact that the program expects a resolution setting above 680x480.
I have seen some prgrams that allow you to change resolutions.
Look at this[noparse]:http:[/noparse]//forums.parallax.com/forums/default.aspx?f=25&m=133054
Some people write for basic VGA some for higher res.
I have seen programs that give you a choice of select the resolution mode.
