DS1307 Object
Beau, in your DS1307 Object, you have it running off of 3.3VDC.· Accoring to the data sheet, the 1307 requires 4.5VDC minimum for proper operation.· Am I reading the data sheet wrong?
Sid
Sid
I think you are reading it correct... I will change it to use 5V instead of 3.3V
from page 2 of the datasheet...
Vpf (Power fail voltage) = 3V ... So 3.3V is cutting it close.
From the same page, the DS1307 "sees" a logic "1" as 2.2V so we are OK here.
from page 6 (Pin 8 description)...
"Primary Power Supply. When voltage is applied within normal limits, the device is fully
accessible and data can be written and read. When a backup supply is connected to the
device and VCC is below VTP, read and writes are inhibited. However, the timekeeping
function continues unaffected by the lower input voltage."
Although I am stretching the "normal limits" with the power supply, I interpret the
statement...
"...the timekeeping function continues unaffected by the lower input voltage"
...to mean that even though I am supplying the DS1307 with 3.3V, it's not going to
impact the clock oscillator. (In this DEMO, I am also driving the 32.768kHz from the
Propeller) so this could make a difference if you are comparing this to free running
with a crystal.
from page 7 (CLOCK ACCURACY)
Here it does not indicate crystal accuracy correlating to supply voltage so I think we are OK here.
Beau Schwabe
IC Layout Engineer
The old DS1307 uses the backup battery as the reference for low voltage detection, and it goes into backup mode when the power supply voltage drops below Vbat+1.5. With a 3 volt backup, that puts the threshold at 4.5 volts. When the power drops below that, the I2C interface goes dead, and the clock operation switches over to the backup battery. If you don't use the backup battery and hook that pin to ground instead, then the I2C interface can usually work to quite low voltages, even at 3.3 volts, although it is speced for operation over Vcc= 4.5 to 5.5 volts.
The DS1338-33 uses an internal 2.8 volt reference instead of the batttery for power switching between Vcc and Vbat. It can use a 3 volt backup battery. The I2C interface goes dead below 2.8 volts.
Note that on either of these chips, the backup mode is not an ultra-low power mode for Vcc. Even in backup mode, the DS1307 draws ~200 microamps from Vcc, and the DS1338 draws ~60 microamps. To get full power down, it is necessary to bring Vcc to zero (and also be sure that the I2C lines are at zero to avoid parasitic power). Then the clock operates at <1 microamp off the backup battery.
Tracy Allen
www.emesystems.com
