HELP! My propeller demo board ain't workin'
OK, I am a little wet behind the ears, but ...
I got the propeller demo brd in hopes of realizing a dream of really really really cheap multiprocessing. But all I get are brief flashes of red and blue lights upon connecting the USB to the back of my computer and then when the brd is “powered on” I get a cycling set of yellow LED (P16-P23) that lead to a solid on set of yellow LEDs. I have a LCD monitor connected, a USB mouse with a PS/2 adapter, and a std PS/2 keyboard.
If I disconnect the monitor, mouse, and keyboard I get the same thing, cycling and solid on yellow LEDs.
I searched high and low for documentation, but alas there appears to be no trouble shooting guide or FAQ for this nice board. I read the Propeller Manual every nite before I sleep with dreams of really really really cheap multiprocessing. On tear stained Propeller Manual pages I cry out for...
HELP!
drt
PS
If there is howto's for the demo brd from other newbie experiences that I have overseen, please point me to it.
HELP!
drt
PS
1) Do the LED's show a specific pattern (that you can tell) or are they totally random?
2) Have you run the Propeller IDE program and have you been able to identify the Propeller? (F7)
It is possible that your Propeller did not end up with the default program "Graphics_Demo.spin"
loaded into the EEPROM.· I have attached this file, but·you should be able to locate it in your·install
directory under "Examples--> Library".
Please let us know what your results are.
Beau Schwabe
IC Layout Engineer
No the LED initially scan from p16 to p23, then from p23 to p16, then from p16 to p23, then all LEDs from p16 to p23 are lit.
>>2) Have you run the Propeller IDE program and have you been able to identify the >>Propeller? (F7)
When I try to detect the board I get: No propeller chip found on any
COM port … scan com1 … scan com2
>>It is possible that your Propeller did not end up with the default program >>"Graphics_Demo.spin"
>>loaded into the EEPROM. I have attached this file, but you should be able to locate it >>in your install
OK, but it appears I can’t connect to the brd, so I can't upload code.
In requard to the USB/PS/2 mouse I have used it on many of my other computers without a problem, but I will pickup a "real" PS/2 mouse today, If I can still find one, maybe at walmart
.drt
Have you installed the FTDI usb driver?
Graham
As drFrankenstein said egor, "IT's A L I V E !!!!!!", BRD connects on COM4.
Where is "loading the FTDI driver" documented? Guess that what I get for working on stuff like this a 2am in the mornin'
Thanks for all your help!
.drt
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
Sorry it took me so long to reply today, I've been at the State Fair most of the day with my daughter
I'm glad your Propeller is alive!
CJ,
I will let someone know about a link to the FTDI drivers.
To me it makes sense that they should at least be on the Propeller download page, if not embeded in
the Propeller install program itself.
FTDI Drivers
Beau Schwabe
IC Layout Engineer
