emic TTS module (#30006) speaker amplification
Hello,
I'm using the emic TTS module (#30006) that can be found on paralax (the female voice version). It's the SIP version (the OEM version doesn't exist).
I connected a speaker to it (8 ohm 1 watt). The datasheet say's it can output a 300mW signal.
Apprently that's not loud enough.. it's pretty low..
so.. it has another pin called the Aout pin which can fee d through your own amplifier.. and then to whatever speakers you want..
my question is.. i don't know the first thing about sound amplification. what would be a good circuit for that??
thanks,
the datasheet for the device is on the parallax site. the output specs of that Aout pin is towards the end of the datasheet under electrical chracteristics
thanks, hopefully someone cna help
thanks,
·· A note on the speaker you connected...If it's not inside an enclosure, it won't sound very loud at all.· Speakers require an enclosure in order to project their sound properly.· Is this one enclosed?· If not you can get some of the effect I refer to by plcing the speaker over a small cup.
Chris Savage
Parallax Tech Support
I have to try that. I won't be able to try it till later though.. It might work, cause i don't need it too much louder than it is.. just alittle more.
thansk for the suggestions..
however.. if other people read this thread. please still post your thoughts on amplification
and it definatly works a whole lot better.
however. i think i should still learn about sound amplification. and i may still need it (I have to see how this project rolls along over the next month or so).
So... it would be cool if peple still posted their knowledge about amplifying audio signals
thanks
There are a lot of audio amplifier chips available. The LM386 is an oldie, but there are a lot of different power levels and capabilites from complanies like National and TI. The cheapest thing is to buy an amplified computer speaker from surplus.
Tracy Allen
www.emesystems.com
it sounds better.. like i personally am okay with it.. but this is for a grade and i don't know if it will be loud enough for my graders lol...
i'll look into those chips..
I like building things but I try not to re-invent the wheel.
Lee
