Sx52(48) vga - 64 colors!!!
cbmeeks
Since Bean has done such a great job with NTSC and I felt like I should just wait to see what he comes up with the next couple of weeks, I thought I would dig up my old VGA code and get it going.
First thing I have to mention is that my SECOND camera is broke! argh...dang kids keep breaking my cameras.
Anyway, below is the source in ASM that will generate a nice color orange on a VGA monitor.
If anyone needs help wiring a VGA connector let me know and I can explain how I did it. When I get a new camera I am going to take some pictures so please be patient.
Also, when I get that camera I am going to do an official tutorial on my new site (shameless plug ahead) www.codershangout.com
Enjoy!
Coders' Hangout
A place for programmers to hangout!
http://www.codershangout.com
METROID?
Metroid Classic
Enjoy!
;TITLE: sx52_vga_01
;PURPOSE: SX52 based GPU
;AUTHOR: cbmeeks
;CONNECTIONS:
; TAPE = VSYNC
; hsync = rc.1
; vsync = rc.0
;DETAILS:
; 470
; RB.0---\/\/--|
; 1.5k +------------- RED (0.0 - 0.7V)
; RB.1---\/\/--|
; 470
; RB.2---\/\/--|
; 1.5k +------------- GREEN (0.0 - 0.7V)
; RB.3---\/\/--|
; 470
; RB.4---\/\/--|
; 1.5k +------------- BLUE (0.0 - 0.7V)
; RB.5---\/\/--|
; RC.0------------------------ VSYNC (5v OK)
; RC.1------------------------ HSYNC (5v OK)
; RB is used for the image signal.
; You have 8 bits to do what you want.
; I recommend using 6 bits so that you get 2 bits
; per color (RGB) giving you 64 colors.
; Make sure RB doesn't go over 1 volt! (0.7v is the spec)
; If you have any questions, please ask!
; cbmeeks
; cbmeeks@gmail.com
; http://www.codershangout.com
;-------------------------- DEVICE DIRECTIVES --------------------------
DEVICE SX52,CARRYX
FREQ 80_000_000
DEVICE OSCHS3 ; High-speed external oscillator
DEVICE IFBD ; Crystal feedback disabled
DEVICE XTLBUFD ; Crystal drive disabled
IRC_CAL IRC_SLOW ; Calibrate Internal Crystal to the slowest setting
RESET Initialize
; REGISTERS
; VARIABLES
org $10
bank_0
d1 ds 1 ; general counter
d2 ds 1 ; general counter
d3 ds 1 ; general counter
d4 ds 1 ; general counter
Pixel ds 1 ; current pixel
ScanLine ds 1 ; current scanline
PixelCount ds 1 ; number of pixels wide
hsync equ rc.1
vsync equ rc.0
WHITE equ %00111111
BLACK equ %00000000
;------------------------ INITIALIZATION ROUTINE -----------------------
org $02 ;allow 2 for the debugger (PAGE 0)
; HORIZONTAL SCANLINE 31.77µS
HScanline
;SYNC PULSE 3.77us
clrb hsync ;(1)
mov w, #$4B
mov d1, w
hsync_0:
decsz d1
jmp hsync_0 ;(300)
;BACK PORCH 1.89us
setb hsync ;(1)
mov rb, #%00000000 ;(2)
mov w, #$25
mov d1, w
backporch_0:
decsz d1
jmp backporch_0
;ACTIVE VIDEO 25.17us
mov rb, #%00001011 ;(2) ORANGE HERE
mov w, #$1F
mov d1, w
mov w, #$02
mov d2, w
active_0:
decsz d1
jmp $+2
decsz d2
jmp active_0
nop
nop
;FRONT PORCH 0.94us
mov w, #$10
mov d1, w
frontporch_0:
decsz d1
jmp frontporch_0
jmp $+1
ret
BlankLine
;SYNC PULSE 3.77us
clrb hsync ;(1)
mov w, #$4B
mov d1, w
bhsync_0:
decsz d1
jmp bhsync_0 ;(300)
;BACK PORCH 1.89us
setb hsync ;(1)
mov w, #$25
mov d1, w
bbackporch_0:
decsz d1
jmp bbackporch_0
mov w, #$1F
mov d1, w
mov w, #$02
mov d2, w
bactive_0:
decsz d1
jmp $+2
decsz d2
jmp bactive_0
nop
nop
;FRONT PORCH 0.94us
mov w, #$10
mov d1, w
bfrontporch_0:
decsz d1
jmp bfrontporch_0
jmp $+1
ret
; SETUP
Initialize
;Configure port settings
mov rb, #%00000000 ;Port B output zero
mov !rb,#%00000000 ;Port B all output
mov rc, #%00000000 ;Port C output zero
mov !rc,#%00000000 ;Port C all output
;other setup
; MAIN LOOP
Main
;SYNC LENGTH 0.06ms
clrb vsync
call BlankLine
call BlankLine
;BACK PORCH 1.02ms
setb vsync ;(1)
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
;ACTIVE VIDEO 480 lines (15.25ms)
mov ScanLine, #240
LOOP1
call HScanline
call HScanline
djnz ScanLine, LOOP1
;FRONT PORCH 0.35ms
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
call BlankLine
; JUMP BACK TO MAIN - Total lines:
jmp Main ;goto main
Coders' Hangout
METROID?
Metroid Classic
I guess it would help if I had a working camera.
I played with it some more this weekend and got 256x192 resolution but that was pushing it. 160x192 looks pretty good. I hope to get some SRAM working with it soon.
cbmeeks
Coders' Hangout
METROID?
Metroid Classic
I hope you have better luck using the SRAM than I'm having...
I used SRAM on my data logger without any problems, but I guess with the video interrupt accessing the RAM at the same time the main code is accessing it is causing me all kinds of problems. I've been working on it for days now...
Right now, it goes goofy for the first 5 seconds then it works fine ??? If I reprogram the SX without turning off the power, it goes goofy again for 5 seconds... ARRRG.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
why are you having the main code and video interrrupt access the SRAM at the same time? Or is that something you are trying to fix. I would try to build the scanline (reading from SRAM) during the HBlank and only allow the main code to access the SRAM during VBlank
Coders' Hangout
METROID?
Metroid Classic
Good news! I just received my brand new $3.99 webcam in the mail yesterday from eBay! hahahaha
So I will be able to take some lo-res videos of my VGA circuit and post them tonight or tomorrow.
Coders' Hangout
METROID?
Metroid Classic
So the main code can write to SRAM anytime (much faster).
But I still have the startup problem...
Bean.
Coders' Hangout
METROID?
Metroid Classic
Then let's say I clear the screen to red, there will be less of the black. After about 5 or 6 clears the screen is fine (no black).
I'm beginning to think it's my PCB, I can't think of anything else. Because even if I·only access SRAM duing VBlank, I still get the problem.
Bean.
Post Edited (Bean (Hitt Consulting)) : 9/14/2006 2:22:09 PM GMT
I chalked it up to me not clearing the SRAM correctly and it was displaying garbage.
I will see if I can find those pics
Coders' Hangout
METROID?
Metroid Classic
