USB to serial IC in DIP package
Hey guys,
I did some searching on the internet last night through Google trying to find some USB to serial IC in DIP package. I found some from Delcom-Eng but was wondering if there is any other ones out there? Thanks.
Matt
Matt
Parallax sells two different types, the first has a standard serial plug, the second has a 4 pin header. The second type is very easy to use on a bread board, by sticking a four pin header into the board and plugging the dongle onto the header.
If your intent is to provide a USB->Serial interface for a Parallax product, another company's solution may or may not work, Parallax uses some control signals in the serial that some companies do not implement.
Paul Baker
Yes, the main reason why I am asking for the IC in DIP package is for prototyping. Once I get a working circuit on the breadboard I will go and buy the SMT packages of everything and make up PCB for them. I wish I could keep all the IC’s that I might be using in DIP package but then the final board might be to big and bulky because of it. The only problem with the dongles is that I will be splicing up a USB cable and having it permanently attached to the PCB. I also don’t know if I will be using a stamp or not for this project. I might be if I can find a useable IC for this.
Matt
·· See Paul's second link above or the link below, which is a smaller version and uses less parts.· I guess my question is what do you mean you have to splice up a USB cable?· Even if your final application won't use a standard USB cable that's no reason not to use the dongles suggested for prototyping.· The circuitry will be the same.· Take care.
http://www.parallax.com/detail.asp?product_id=32201
Chris Savage
Parallax Tech Support
csavage@parallax.com
Let me reword this or try to explain it better. I would like to put my final application inside a box and would like for this box to be as small as possible; one reason why I am going to SMT in the end and why I am using USB. Besides have an USB plug on my application it will have a 6 inch USB cord coming out of the box that plugs directly into the USB port on my computer. I hope that explains what I want to do better. I will post a sketch of the "box" later today.
Matt
·· I understood that part...That is the final project...In the interim though you would normally use the through-hole parts to prototype.· Do you think the links above will do what you need?
Chris Savage
I can see·your point because a SMT is often deployed with some pins eliminated and you end up without the ablity to explore all the modes or options. [noparse][[/noparse]I had this problem with MCP2515 chips - I could by them premounted and preconfigured, but with limitations that I didn't like or understand]
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 9/6/2006 6:47:56 PM GMT
Yes it will work for what I need to do during the design and testing phase. Is there any more info about it? Datasheet, manual???? Things of that nature? Thanks.
EDIT: Nevermind. I see on the top part of the Prop plug it labels what each pin is. I guess that is smart. Is there still schematics for it ?
Really???? I better stop by their site and see what they got. They might have what I am looking for and then some. Thanks for the link.
Matt
Post Edited (Matt Battle) : 9/6/2006 11:12:18 PM GMT
Chris Savage
I plan on using the power coming from the USB port to supply my final application and was wondering if I should use a 5V VR to make sure it’s a constant 5V being supplied to the components. I know I will need a 3.3V VR for the FT232BL I will be using but should I worry about a power spike coming through the 5V line? Has anybody encounter this before? Thanks.
Matt
·· If the power consumption from the 5V circuit is less than 100 mA you shouldn't need a regulator...USB is already regulated at 5V.· As for the FTDI chip, it has it's own internal 3.3V regulator, as well as a pin to dictate the I/O voltage.
Chris Savage
Oh okay. I just looked over the blocked diagram for the FT232BL and I am amazed to what is on this chip. I am going to save a lot of space using it. On the same note though I should still use some caps. to clean up the line coming into the circuit? Do you know of an equation that I could use to figure out the size I should use? In the past I always referred to datasheet of the VR I was going to use to tell me what caps I needed. Thanks.
Matt
