Library Folders
I have been working my way through the Propeller Manual, and am doing fine with it. I notice there are just two possibilities for searching for library files. I would really like to see a user definable library path added.
When I am writing software, I prefer to keep my personal written libraries (objects) that I have already tested and debugged in a folder separate from those things I am currently working on. I don't care for putting my tested objects and such in with vendor (in this case Parallax) supplied stuff.
I am looking forward to being able to start working with the Propeller this week, if my PRC board arrives. The more of the manual I get through, the more anxious and excited I get about working with the Propeller and the more possibilities I see for it.
I can handle complexity.. It's the SIMPLE things that confound me.
The Dynaplex Network - Home of The Octabot Project
http://www.thedynaplex.org
Cheers,
Simon
Actually, it would be REALLY nice if we could define what all of the library folders are.
It could be done easily by having the Propeller Tool look at an environment variable such as PROPELLER_LIB and searching the paths contained there until what is needed is found or it doesn't find anything and generates an error.
PROPELLER_LIB would default to the current standard paths when the Propeller Tool is installed.
These two topics are not really related, and I think that thread is getting to confused and hard to follow. People there are talking about two things that should not necessarily be connected and in some ways the whole issue is being over complicated in my opinion.
This topic is just discussing the paths the Propeller Tool searches for files when it compiles a project. The two topics are only intertwined if you insist that the local directory structure on a developer's computer be tied to the way CVS might be setup, which I do not think is a good idea at all.
I want to be able to define my own development directory structure, independent of what soembody somewhere else might have setup. This is just me though and I just want the flexibility to do as I want for my development environment.
Maybe I am misunderstanding something from that other thread, so please correct me if I am wrong. I am just asking for a simple method to define my own local development directory structure.
Addendum: One thing that's always in the back of my mind when suggesting stuff like this is the impact on Jeff's IDE coding and Chip's compiler coding. On the surface, neither the hierarchical directories nor the PATH idea would seem to entail anything terribly disruptive. But where this could get pretty complicated is in the creation of archives. This is because an archive will be created in the creator's library environment but has to be usable in a different environment. It may be as simple as prepending the archive's root directory to the user's path so its objects supercede any the user may already have. But it's definitely worth examining this situation more closely.
Post Edited (Phil Pilgrim (PhiPi)) : 9/5/2006 7:46:30 PM GMT
This is exactly what I would like to have in the Propeller Tool now and what I suggested in an earlier post here.
I agree. I do NOT want to have to specify file paths within my source code just so the compiler can find something. Having to do so is just a bad idea.
