Anyone made an SX Eagle Library? — Parallax Forums
T ChapT Chap Posts: 4,254
edited 2006-09-03 06:03 in General Discussion
I was about to build a library but hoped someone already has posted one already. Thanks!
  • John R.John R. Posts: 1,376
    edited 2006-09-01 00:52
    See this thread: http://forums.parallax.com/showthread.php?p=602049, and check out about the fifth post down, from StarMan. There is a Scenix4 library with the SX stuff available from Cadsoft.
    John R.
    8 + 8 = 10
  • T ChapT Chap Posts: 4,254
    edited 2006-09-01 01:20
    Got it Thanks John
    edited 2006-09-01 21:12
    Unfortunately the library at cadsoft appears to be to old to load on my newer version. Just a heads up. I get an error that the data structure is older than 4.11
  • StarManStarMan Posts: 306
    edited 2006-09-01 21:18
    I'm using v4.15 and it works fine.
    edited 2006-09-02 00:21
    I have V4.16, must be a problem some where. There is also a Ubicon library that gives the same error. No big deal, I'll just make it. Thanks
  • PaulPaul Posts: 263
    edited 2006-09-02 23:47
    I have an SX28/DP in my chips library I made because I didnt like the scenix layout. Theres also a resonator an other stuff. It works in 4.11.
    Paul
    Paul Those worked great! Thanks for uploading
