Question about parts and Interfaces
I know this isn't the best place to post this.....but because I'm designing with the Propeller.....I figure it will work.
Do any of the people here, have a list of parts they normally use on thier surface mount designs. This is my first surface mount board....so I'm working hard on just finding parts. I'm looking for standard part numbers for Mouser,Digikey,Jameco.
I usually have a spreadsheet of parts that·I use....to keep the process organised.
I'm a solder junkie...so I don't think it will be hard to transition to surface mount.....if I can find the parts.
Also...what is the optimum interface for the Propeller for programming? (I want to ensure that I can interface with the chip after the board is finished)
Please understand ....I'm designing sight unseen. I don't not own a Propeller chip...but I know what I need.Most of my project is I2C and Serial communication. I have a few ADC items.....but these are actually quite easy.
I have the chips on my list...like the MAX1202(12bit ADC with 3.3v interface)·and the MAX3232E(Rs-232 communication interface 5v to 3v).
The things I need are capacitors, resistors, enhanced N channel Mosfets, Voltage regulators(3.3v, 5v, 6v)........and the like.
Thanks for the help,
James
James
·· We in Tech Support highly recommend prototyping your system before designing a PCB around a chip you don't own.· You could use a DIP-40 version of the chip for prototyping.· Take care.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 8/31/2006 5:13:14 PM GMT
Ditto on Chris's advice to prototype first on an easy to manipulate physical platform like either the Demo Board, Wulfden's Propeller Robot Controller, or the PropStick on a breadboard strip.
After one too many tombstoned resistors, though, you'll want to move to solder paste and an oven. Use a paste with RMA flux. You have to clean it off afterwards with 99% isopropyl alcohol and a toothbrush, but it "takes" better than the no-clean types. I use a Panasonic infrared toaster oven with electronic time and temperature controls. The profiling has to be done by hand (2.5 min. at 285F, then 0.5-1.0 min. at 460F), but it works. At this point 0603s become realistic for passives, too. (I've never tried 0402s. The 0603s are about the limit of what I can see, as it is.)
With either method, make sure you have plenty of small caliber solder wick on hand. It can turn a globby mess into a work of art!
I appreciate your insight into this, but I have a project that would benefit from a smaller chip. Size is a problem here. I hate to be a cheapskate, but I really can't afford to build two systems (one prototype and one production).
That is a good idea.....that would make the schematics easier to draw and the interfaces would be known to work.
Phil,
I don't have many·items on the board, a few resistors, an op-amp, some capacitors, some max chips like I previously stated,·some voltage regulators, and some headers. The board is not really complicated. I just want to·insure the applied components will work correctly.
Would you consider·baking a board if I sent it to you with the components? I would pay for the service ofcouse.
To all.......could you passively approve a design schematic if posted here? I was planning on getting opinions of my final schematic before having it etched/routed.
Just an Idea......
James·
·· The cost of a design error in a production PCB·could be a lot more.· Just some advice.· Take care.
Chris Savage
Thanks.....I do appreciate your view.....I know you deal with this kind of thing everyday, and appreciate the support you give on the forum and otherwise.
I just will have to make sure not to make a mistake
James
If you go from straight from "brain to PCB", you definitely need to do a cheap (no soldermask or silkscreen) proto board first!!! There's just no getting around the high probability of errors on the first go 'round, regardless of how few parts there are. Then you need to take one plain and one assembled proto board to a production assembly house for a quote and a critique. And believe me, they will critique it. They'll say things like, "You used the manufacturer's suggested pad sizes? No good. Make 'em bigger.", and "Where are your fiducials?" It's a rite of passage that's not to be missed! But a good assembly engineer will save you all sorts of grief down the road. So it's well worth the time to go visit. But if they don't spend the time with you, go somewhere else. They're not worth dealing with.
As to populating and baking your board for you, I'm afraid I'll have to decline. Sorry. It's all I have the patience and eyesight for to do my own.
You're embarking on an adventure, and there will be frustrations. But don't get discouraged. You will prevail in the end.
Good luck!
Phil
That is a good idea.....plus I doubt that I ever mass produce this design.
What are fiducials???·· I have a lot to learn.
I thought I would ask......hey I tried right?!!·· I will populate it myself. I'm just not sure what components are the right size......I really need a chart of part differences....there seems to be millions of variations on the same theme.
But on that same note.......I will still submit my drawings to be critiqued...builds character.
I'm not an electronics level guy by trade....I have basically learned all of this on my own over the last 15 years. I'm just taking the next step into the abyss.
Thanks for all the support and advice.
You guys are really great,
James
Post Edited (James) : 9/1/2006 3:26:09 AM GMT
Fiducials are reference pads on the board that the automated pick-and-place machinery uses for alignment. You can read about them here: www.tkb-4u.com/articles/other/fiducial/fiducial.php
I learned a new term.
James
Unless you somehow already know what size and shape to make the fiducials, how much soldermask clearance they require, and where to put them, you might want to read the article. The same road that's paved with good intentions is also littered with bad assumptions.
Here are some other design rules to consider. Numbers 1 through 4 are fabricator-dependent, so you should check with your desired fab house for more precise recommendations.
1. Make sure trace widths and separations at least 0.008".
2. Silkscreen lines should be at least 0.005" wide.
3. Add about 0.006" overall (0.003" radius) to pads for soldermask.
4. If pads on a fine-pitch part are closer than X, use a siingle soldermask cutout for the whole row of pads to prevent a fine web of mask between pads which could separate from the board. (X is fabricator-dependent.)
5. Pastemask is usually the same size as the pad.
6. Keep at least 0.030" between parts.
In any event, most fab houses will publish their design rules on their website. Assembly houses will make additional recommendations about pad sizes for different kinds of parts. Their concerns mostly deal with making sure there's enough pad around the part for a visible solder fillet. This makes the connection not only more reliable but also easier to inspect. For leaded parts like SOICs and QFPs, they may recommend different clearances for "heel" (behind the bend of the lead) and "toe" (off the tip of the lead) fillets. Most will pooh-pooh the part manufacturers' recommendations for pad layout as being too tight. (Chip's Propeller QFP layout, by contrast, accommodates plenty of clearance and shouldn't meet any objections.) In any event, the sooner you get your board assembler involved in the design process, the less reengineering you'll have to do.
I'd want to have a working prototyping board too, in addition to the custom made invention board. When you have a new circuit board, there are so many possible causes for it not working. If you purchase something like the demo board or a propstick, you can be assured that you know how to operate the IDE, and that your computer is set up properly to make the connection to the Prop, and that you know how to download a program that will blink an led. When you have only your custom circuit board, all of those things are in the line of possible trouble, and the troubleshooting task can be daunting. That is particularly true if you are hand soldering your first surface mount board. If you have something like a demo board, you can try out the individual circuits of you project one at a time and also the internal Prop objects in an modular fashion, so when you move it to your own board the possible causes of failure are narrowed down to a managable level.
Tracy Allen
www.emesystems.com
I'm using Eagle...so I do have the required files.
Thanks for the encouragement.....I'm sure I will need it.
James
Tracy's design rule checking recommendation is spot on. Some PCB CAD programs have this facility built-in. I use CADINT, which does. I'm not sure about Eagle, though. If it does, use it early, and use it often during the layout process. It will help keep you from painting yourself into a too-tight corner.
I have a small problem that I can't seem to figure out.
I have three voltage regulators on my board. Of which all have three pins.....but Eagle places three pins and one large pad for the main body of the regulator....I hate to be stupid.....what is the large pad for??
I don't get it.....its things like this that really catch me off guard. Is the large pad connected to a +/- supply??
All the documentation of the part(s) do not reference this. Is this just for mounting??
Things like this are the reason I was reluctant to switch my building method. But·times change and we have to comply with them.
Just trying to learn about the new components/methods.
James
If you mount vertically, then the 'mount' would be 'off board', if required.
Do you have a document for the part in question? Is the dimensions from leads to the 'large pad' appear correct, accounting for lead bend radius?
Voltage drop from input to output * load current is a quick calc to determine if the regulator is running warm (or very HOT
Harley Shanko
h.a.s. designn
I have enclosed a picture· from another software that shows the pads. It also gives the part number (provided by me), so you can try and find out what the large pad is for.
I would assume (oh....that dreaded word) it is for a heat sink type solder attachment.....but I'm only guessing.
Let me know what you think guys.
James
Post Edited (James) : 9/2/2006 12:49:12 PM GMT
I looked at the Micrel datasheet for the MIC29300. In it you will find the following info:
1. The -BU suffix means it's in a TO-263 package.
2. The tab is grounded.
3. Pin 1 is input; 2 is ground; 3 is output.
The tab is a heatspreader and gets soldered to that large pad, which you correctly surmised is for heatsinking. (I'm not sure how much of that pad gets pasted, though. But there's probably a paste layer associated with the part in your CAD program that will show you.) If the device will dissipate a lot of heat, you will want to include the pad in your groundplane to make the most thermal mass available to it. If your groundplane is on the opposite side of the board, you can use an array of plated through-holes as a thermal conduit to reach it. Just don't put the holes in your pasted area, else the solder will get sucked into them.
Phil.....I found all the electrical connections ( I had the datasheet)......that was self explanitory....I just didn't know about the large pad surface.
Thanks for the answer,
James
I don't have the regulator data sheet, but if one read it carefully it probably mentions about the thermal tab, its function, and possibly thermal considerations for proper use.
Harley Shanko
h.a.s. designn
I have a datasheet, but it is not specifically for the MIC29300......it contains about five different packages. Maybe that was my main problem.
Where did you get the specific datasheet for that one regulator.
Yea...that is a great idea.....I will have to make a list·of areas with·confusion. This could be the surface mount board design 101!! (Sticky)
This design is not finished....so I can post my progress as I go.....then you guys can say, "Whoa!! wait that won't work!!"
I didn't find anything about the thermal tab being grounded or it getting soldered....so that is the reason for me asking.
I will continue and post pics/files as I go.
What method would be the best?
James
Yours sounds like the datasheet I looked at: TO-220's, TO-263-3's, and TO-263-5's. This is common for many semiconductor products: one datasheet for a family of similar parts. You have to read the fine print to get the specifics for a particular device.
Wow......that sucks....now I feel real stupid. It was in a place that·I just didn't notice it.
On to the next stupid question......I'll have to think of it first though.
James
Some of us on the forum might be almost 'older than dirt', but we can help when we have enough info to know what your needs are. Hopefully, any critiques won't be taken personally; just trying to steer one towards a better solution. (I've done over 100 pc boards, originals and revisions. Some tiny, one about 15 x 18", many through-hole and a number also with SMD parts, many 4-layer, some 6-layer, some with hi-freq considerations -- MECL with 500 MHz clock for part of one design, several with matched length transmission lines, etc.) So some details become obvious when 'eyeballed', like a regulator 'tab'.
For What method is best question:
...Well, many times just a textual description is sufficient, other times some drawing or graphic is better. If you have a digital camera, a '.jpg' shot can be very useful and quick. If you are dealing with a pcb layout, hmmm, maybe a screen dump of the area in question can be sufficient, unless the layout program can output a picture in a useful format.
Harley Shanko
h.a.s. designn
We will keep up the project and all can learn what I'm learning.
I rarely take things personally. Part of learning is being humble enough to know "No one knows everything!".
I may do things that most think are risky....but I do listen to the advice given.
I'm learning a lot of things at once.....so it is a lot to take in.
James
Post Edited (James) : 9/3/2006 1:59:02 AM GMT
Don't feel bad: I read it over at least that many times before I found the part describing the tab connection. The only difference is that I've been through this wringer enough times (but still approaching the age of dirt) that I knew it had to be there ... somewhere!
But it's always worth double-checking these things. On the LM317, for example, the tab is connected to Vout. (Okay, bad example, since the '317 has no ground connection. But still...)
I know that most datasheets contain the needed information....but it was eluding me. That pesky bit of information. Like that specific·bit you are looking for in your program that makes the keyboard bloody. (From the forehead)
Its great to have a place online to learn things like this, and have people to help.
I'm really excited about my project......as long as I can hold out to see it done.
James
Thanks for all the information so far.
I hate to say it...but at this moment, I'm overwhelmed (sp?) with what I have to do. This project has escalated to a point of massive porportions....I hope I'm up to this task.
I'm sure I will have a huge amounts of questions to get this project finished.
James
What about pressure sensors from motorola????
I don't want to have to draw them ....I just started using Eagle.....and don't care to learn that yet.
James L
