Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Anyone made an SX Eagle Library? — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
T Chap
4,254
2006-08-31 23:49
edited 2006-09-03 06:03
in
General Discussion
I was about to build a library but hoped someone already has posted one already. Thanks!
John R.
1,376
2006-09-01 00:52
edited 2006-09-01 00:52
See this thread:
http://forums.parallax.com/showthread.php?p=602049
, and check out about the fifth post down, from StarMan. There is a Scenix4 library with the SX stuff available from Cadsoft.
John R.
8 + 8 = 10
T Chap
4,254
2006-09-01 01:20
edited 2006-09-01 01:20
Got it Thanks John
T Chap
4,254
2006-09-01 21:12
edited 2006-09-01 21:12
Unfortunately the library at cadsoft appears to be to old to load on my newer version. Just a heads up. I get an error that the data structure is older than 4.11
StarMan
306
2006-09-01 21:18
edited 2006-09-01 21:18
I'm using v4.15 and it works fine.
T Chap
4,254
2006-09-02 00:21
edited 2006-09-02 00:21
I have V4.16, must be a problem some where. There is also a Ubicon library that gives the same error. No big deal, I'll just make it. Thanks
Paul
263
2006-09-02 23:47
edited 2006-09-02 23:47
I have an SX28/DP in my chips library I made because I didnt like the scenix layout. Theres also a resonator an other stuff. It works in 4.11.
Paul
lbr
lbr
CHIPS.lbr
11K
CHIPS.lbr
11K
T Chap
4,254
2006-09-03 06:03
Paul Those worked great! Thanks for uploading
Sign In
Register
to comment.
John R.
8 + 8 = 10
Paul
