Multipule RF Transmitters and 1 RRF Recievers — Parallax Forums
deanostzdeanostz Posts: 1
edited 2006-08-27 15:35 in General Discussion
Hello All,
Just wondering if it was theoretically possible to run multiple 433Mhz Transmitters and a Single 433Mhz Receiver at the same time
And be able to pass one way serial data to the receiver from the multiple inputs?
Any Info would be greatly appreciated
Deanostz
Regards
Dean Stevenson
Sydney
Australia
  • David BDavid B Posts: 593
    Yes, you could let multiple transmitters send, only if the transmitters took turns sending so they didn't interfere with each other.
    A serial output should be able to feed several inputs, as long as the inputs don't implement any flow control back to the sender.
    Look at this thread; it has a lot of multiplexing information that may help.
    href="http://forums.parallax.com/forums/default.aspx?f=15&m=102669"
    David
