L298 Compact Motor Driver
Hey guys quick question... imthinking about getting one of these but from the look of it you have to solder everything your self... its cheap sao i might try it but if i could be positive ide rather find a preassembled thing.... so any knowledge on the product would be great thanks!
-Learn somthing about everything, and Everthing about somthing-
Here is a kit, but it will still require soldering:
http://www.hvwtech.com/products_list.asp?CatID=113&SubCatID=146&SubSubCatID=0
<!--StartFragment -->
I just plugged it into a breadboard and did all of the wiring there, however you should really solder it onto a PCB so the center legs can dissipate heat.
It dumps more heat and handles a wider range.
There will come the day when you want real power [noparse][[/noparse]like 1/2 horsepower] and then the HB-25 is a must.
Within similar sized devices, it is a bargain.
You can either buy your way up, or just use the HB-25 from the start.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
http://www.robotobjects.com/scripts/prodView.asp?idproduct=67
Jeff T.
Needs a good heat-sink though (a notable·absence.)
· I truly figure so -- but you might find out differently with the "finger test" (if you can't keep your finger on it when it's running then it needs a heat-sink.)· If whatever only runs briefly, then maybe/maybe not.· If it's running practically continuously (extended periods), then it's more likely.
· Typically, tabs alone don't make it for you; they're not supposed to -- that's why they put the hole in the tab, afterall, to secure the device to the heat-sink.
· A nice touch is that the L298's tab is = to GND (so if your metal case is DC GND, then the device doesn't have to be isolated from it.)
Post Edit --
It's not just the current, it's the voltage, too; it's all about Power, watts: Volts X Amps = Watts
(P = E * I, E = P / I, I =·P / E)
Here's some more from the Flying-by-the-Seat-of-Your-Pants Dept.:
It's a "25W" device and you want/expect 3A, then at the outside the motor has to get by with an·8V supply (25W / 3A = 8V).· A 12V motor running 3A is consuming... 36W.
The datasheet shows, however scantily,·how to parallel the outputs for greater currents, but that's not a panacaea.
Post Edited (PJ Allen) : 8/27/2006 3:24:11 AM GMT
· You don't see the light till you feel the heat.
· I'm seeing a boo-boo face emoticon in your future.
While you see a lot of boards with devices that might need a heat sink, they are often omitted due to the added cost.
With something that your are going to experiment with, having the ablity to pop it in at a later date is quite important.
Hobbyist always discover something and change their minds.
Regarding 'I never soldered anything'....
Google is your friend. There are tutorials.
Good electrical connections are extremely important to having electronics operated properly.
Consider that learning to solder is very necessary.
It really isn't that hard, but it never hurts to practise on something cheap and expendible.
Nuts and Voltage has lots of small board projects that one might begin with.
I suppose Radio Shack has something too [noparse][[/noparse]I haven't seen a Radio Shack for 12 years now, so it is a bit hard for me to know].
My biggest problem with soldering is that I forget that this gets hot.
So, I end up with burnt fingers from trying to do things without tools.
Also, having a good surface [noparse][[/noparse]a piece of glass or a large ceramic tile [noparse][[/noparse]12"x12"] will protect your table top.
Formica will become scared, wood will too.
