Propeller IDE Suggestions or Bugs
Maybe we can start a thread (maybe sticky) with suggestions or bugs found in the current IDE for the propeller.
Example:
When doing a Find/Replace, when it completes a dialog comes up stating how many instances of the task were completed. When you click “OK” it closes the find replace window making it hard to do multiple passes with different parameters.
When using a DAT element the variable and constants cannot be mixed and must be grouped together. It took me a while to figure this out. Maybe the IDE can flag this.
Maybe add a small toolbar to teh top of the IDE with icons such as "Open, Save, Save As, Compile, Load RAM, Update Status" and so on.
-Dan
Post Edited (Direct Digital Labs) : 7/27/2006 8:29:16 PM GMT
Example:
-Dan
-Parsko
OS != IDE, with the exception of Emacs, I guess
A rant:· Searching for "ide, suggestions" does not find this topic.· I hate the search function on the forum.
I've already posted an issue regarding printing - namely:
If I try to print landscape, the print appears in landscape orientation, but only as wide as protrait and it 'misses' a load of lines between pages (i.e. it still thinks it's printing portrait).
I've also found that adding line numbers to the print 'chops' characters from the right-hand edge of the print.
Cheers,
Simon
My project was a little too loose in breaking up code into too many separate spin files, each of which included other spin files. Then this morning I added yet another spin object, compiled, and got the message something like "Error - over 32 objects".
But the the IDE broke internally. After editing to remove that last object include, the Propeller tool wouldn't save the reverted code, and when I shut it down, came up with a Windows error message, including:
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="Propeller.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="Propeller.exe" SIZE="812032" CHECKSUM="0xA3AFD1D" BIN_FILE_VERSION="0.9.8.1" BIN_PRODUCT_VERSION="0.9.8.1" PRODUCT_VERSION="0.98.1" FILE_DESCRIPTION="Propeller Tool" COMPANY_NAME="Parallax, Inc." PRODUCT_NAME="Propeller" FILE_VERSION="0.9.8.1" ORIGINAL_FILENAME="Propeller.exe" INTERNAL_NAME="Propeller Tool" LEGAL_COPYRIGHT="2004 - 2006" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xCED08" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.9.8.1" UPTO_BIN_PRODUCT_VERSION="0.9.8.1" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" VER_LANGUAGE="English (United States) [noparse][[/noparse]0x409]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x4CE79457" BIN_FILE_VERSION="5.1.2600.2180" BIN_PRODUCT_VERSION="5.1.2600.2180" PRODUCT_VERSION="5.1.2600.2180" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF848" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2180" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2180" LINK_DATE="08/04/2004 07:56:36" UPTO_LINK_DATE="08/04/2004 07:56:36" VER_LANGUAGE="English (United States) [noparse][[/noparse]0x409]" />
</EXE>
that will be a great way to attract devs [noparse]:)[/noparse]
ALIBE
I have to cancel this a couple of times before it stops popping up.
