New RFID Kit user
We have hooked-up the reader ant powered it up.
Good news is that the LED does he Green/Red thing as expected.
Bad news is we can't seem to see the output stream.
Our hope had been to use HyperTerminal on a PC to see the message.
2400 bps 8 - 1 etc but no visible results.
Hanging a scope on the Sout lead shows something happens on the Sout pin when we hit the button grounding the enable pin.
Does the reader take a while to think about the stream?
Maybe we are being too impatient?
Anybody got some clues for a newbie?
Chris Savage
Parallax Tech Support
csavage@parallax.com
This will probably not work, as the reader works on a TTL signal, not at full fledged RS232 voltages.
John R.
8 + 8 = 10
OK, it sounds like we need to buy a STAMP and have "it" talk to the PC.
Is that a sensible plan?
Or, is there an easy level changer circuit available?
Google MAX232
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
If you want to go the "STAMP" rout (a very viable alternative), you may also want to look at an SX chip. With the SX deals going on now, you can get into it very inexpensivly and program with SX/B.
John R.
8 + 8 = 10
