Memsic2125 theta question — Parallax Forums
MacGeek117MacGeek117 Posts: 747
edited 2006-08-24 04:00 in Propeller 1
I've been trying to Spin without a Prop and have moved on to the Memsic 2125 driver, but my project needs the theta values for forward, back, left, and right. Could someone please post the values for those directions?
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
    edited 2006-08-23 18:30
    RoboGeek,
    I am not exactly sure what you are asking?
    Beau Schwabe
    IC Layout Engineer
  • MacGeek117MacGeek117 Posts: 747
    edited 2006-08-23 18:40
    In the NV column, "No more coffee spills", the brad measurements for 0 degreees, 90, 180, and 270 degrees. I would like to have the same for the raw theta values.
    RoboGeek
    www.parallax.com
    www.expresspcb.com
    www.startrek.com
    edited 2006-08-23 19:46
    RoboGeek,
    BRADS are "Byte radians" ... Simply a way to represent 0-360 deg within a BYTE value ranging from 0-255
    BRAD = (DEG / 360) * 255
    ..or for integer math...
    BRAD = DEG * 255····· <--- For the Propeller (360 * 255) would not be an overflow problem
    BRAD = BRAD / 360
    Applying the above formula...
      0 Deg = 0 Brads
     90 Deg = 63 Brads
    180 Deg = 127 Brads
    270 Deg = 191 Brads
    The RAW theta values in the object I posted are returned as a 32-bit value but need to be shifted right 19 places
    to create a valid 13-bit value that ranges from 0 to 8192 ($0-$1FFF)
    deg := acc.theta >>19
    Brads := deg * 255 / $1FFF
    13-bit degree    0 =   0 Brads    '  0 Deg
    13-bit degree 2047 =  63 Brads    ' 90 Deg
    13-bit degree 4095 = 127 Brads    '180 Deg
    13-bit degree 6143 = 191 Brads    '270 Deg
    Beau Schwabe
    IC Layout Engineer
    Thanks, Beau!
    RoboGeek
    www.parallax.com
    www.expresspcb.com
    www.startrek.com
