Getting started need some info
I am helping a friend build a controller board I owe a favor to. He is developing some signs fo sale that use LED's that light up approximately 4 words(maybe 20 leds per) in whatever sequence he wants. There will be cases for some of his customers to put running lights going around the sign, sort of an led chase sequence.
I was looking at using the SX28AC/DP-G for the simple version of his signs that just flash words on and off in sequence, but if the need came up to have it run a lot of leds in a circle I'd have some thinking to do to accomdate that many individual led's. A matrix would work with the remaining pins, maybe 8 x 8 for a total of 64 leds. Maybe there I could add a daughtboard later that had a serial link to the SX, and would give me a lot more outs?
Ok seconds issue. I don't quite get the SX key. Is it a device to plug into a 4 pin header that I mount on my PCB? Also, do I need a resonator, if so what speed? I gather that there is an onboard eeprom or flash memory, so there is no need for external program storage. If that is true, all I need is the chip and the resonator? If I put a 4 pin header(.10) on the board for programming, thats all I need right?
Third. What about using mosfets to switch the low side of the led banks? Just a resistor off the SX pin to a mosfet, and the board is finished unless someone has a better plan for low speed switching, I am open to ideas.
Thanks for any help
Thanks for any help
The SX can run from it's internal clock at 4MHz, 1MHz, 128KHz, or 32KHz. The speed depends on your applications. However, the internal clock is not very accurate (± 8%). So if you want to do serial communication you will need to use an external resonator. If you're just flashing LEDs, the internal is fine. The faster the clock the more current the SX will consume.
The SX28 has 2K of flash memory on-board to store your program.
You will need a 10K resistor from the /MCLR pin to the Vdd pin. And I would recommend a 0.01uF capacitor between the Vss and Vdd. Everything else is optional.
Sounds like an interesting project, keep us informed of your progress and feel free to ask more questions.
Mosfet would surely work. If you have multiple·LED banks you may want to use something like the ULN2803 chip.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Post Edited (Bean (Hitt Consulting)) : 8/22/2006 12:03:28 PM GMT
If you do put a SX-Key header on your board, I would put a 0.01uF cap as close as possible to the header pins between the Vss & Vdd pins. The SX-Key draws alot of current when it fires up and if the voltage drops you will get error messages. The cap is just insurance, but I always put it on my boards.
Bean.
