SX/B: Variable number of subroutine parameters
Today's question:
I have a need to pass a variable number of parameters to a subroutine. The valid data range for each parameter is 0x00 through 0xFF, so I can't use a "padding" parameter and maintain the ability to send four bytes (some commands are four bytes long).
I was happy to see there's a variable that contains the number of parameters passed to a subroutine -- but the SX/B compiler complains when I try and pass less than four parameters with "invalid number of paremeters".
Is there anyway to do what I want? There's no null in SX/B AFAIK?
Thanks!
-marc
Thanks!
-marc
MySub SUB 0,4 ' zero is minimum number of parameter, 4 is maximum number of parameters
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Thanks for the quick response! [noparse]:)[/noparse]
-marc
Bean.
That was 'remembered'; but thanks for pointing it out.
Am I right in thinking you're 'responsible' for the SX/B compiler? If I may be so bold, as a design request, going to eight (8) passable parameters for a function/sub-routine would really be useful.
BTW...SX/B rocks! A very good progression for those of use used to Stamps. Passing of parameters, interrupts, better I/O access...
-marc
· Guilty...
· The 4 parameter were "designed-in" because some of the high-level commands need 4 bytes of tempory storage.
· To have 8 parameter bytes would decrease the variable space by 4 bytes. Not good.
· But you can pass an array name as a single byte parameter and access as many elements as you need. Using the __RAM() virtual array.
· Just ask if you want an example.
P.S. Thanks for the kind words about the compiler. I will forward them to Ken [noparse];)[/noparse]
Bean.
An example of passing the array would be great! Thanks!
-marc
Bean.
