Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
SX/B: Using a variable as a the upper bound of a FOR loop — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
geekything
53
2006-08-21 04:32
edited 2006-08-21 11:15
in
General Discussion
Is it safe?
For example:
FOR Y = 1 to X ... NEXT
-marc
Bean
8,129
2006-08-21 11:15
Sure, no problem.
What you cannot do is:
FOR Y = 1 TO Y NEXT
Bean.
Cheap 4-digit LED display with driver IC
www.hc4led.com
Low power SD Data Logger
www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Sign In
Register
to comment.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
