ADC1298 and BS2 Help.
Hello all,
Need a little help understanding how to read ADCs. I'm using BS2 and the ADC1298 adc. I referred to APPKIT: "Using the LTC1298 12-bit Analog-to-Digital Converter". If I'm reading DC voltages the values read are steady. My project will require that I read 60hz AC signals (actually a half wave will make it to the ADC input). I can also read these voltages, but·these readings are all over the board (which I think I understand because·it's·mesuring·where the wave happens to be at the time I ask for the conversion). The final project will have a window of about 10 ac cycles to get the votage reading.
Should I take several readings and average (in this case will I need to control the clock or sample rate, I'm just continously looping now at what ever speed the BS2 is running)?
I have even considered filtering the halfwave input to look more pure DC.
Any of your tips will be appreciated,
Bruce
Bruce
If you are trying to find the amplitude of the AC signal, you would be better off just applying the half-wave to an RC filter and reading the steady DC voltage that results.
Is that the intent of reading the AC signal ? If not, what IS the intent ?
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Thanks Bean,
Bruce
