SX/B: WATCH an array element?
Paul
I'm trying to WATCH an array element (in SX/B 1.51) defined as follows:
ADC··var byte(8)
The 'new'·format·didn't work:
·Watch ADC(0)
It 'compiled' to: ADC+0,8,UDEC which reported an error on the "Invalid type '8'
This didn't work either:
·WATCH ADC(0),8,UDEC
It has an "invalid type ','
This·compiles but I suspect it is only looking at ADC(0):
·watch ADC,8,UDEC
How·would I WATCH ADC(1) thru ADC(7)?
Paul
ADC··var byte(8)
·Watch ADC(0)
·watch ADC,8,UDEC
Paul
It seems the WATCH command in SASM doesn't like the "+" sign.
You can make it work by creating an alias to the individual elements, and watch them.
Or if you want to see the array as a string you can use WATCH ADC,8,FSTR in this case the "8" is the number of elements in the array.
I will look into correcting this for the next release...
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Paul
