Pull down network... Why doesn't it make sense...
I'm trying my hardest to see how this works... and for some reason, I just cant see it.
What I need is either a logic HI or LOW (IE Not floating) on the inputs to the PCF8574.
So, all the resistors have one end tied to ground...
The other end goes through the DIP switch... which goes into the inputs of the PCS8574.
Ok, no problem here.· Now, if I tie all the inputs to the PCF8574 to HI, will they all appear as HI no matter what the position the DIP is in?
Tieing the inputs to GND doesn't seem to work either, so I've either missed the boat completly... or...
Well, I won't consider the or here... please point out my wiring error...
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
(This thread should be moved shortly... it's off topic... I wasnt paying attention when posting... sorry guys...)
Chris Savage
Parallax Tech Support
csavage@parallax.com
