Using ~ (not) operator in array index
Zoot
I've got a pretty complex program that I decided to re-work over the weekend and I hit a problem.
I want to access some arrays (mostly for two motors and two sonars) using a single BIT and the not operator. However, using the ~ operator in the array index appears to crash. I tested this using simple debug program, so I am wondering if I am off or if I have to do a workaround, or what.
The workaround I found is below (which works), but boy, I don't see why the above shouldn't work since I can do other operations to get array indices?
somearr VAR Byte(2) somebit VAR Bit Reset: somearr(0) = "A" somearr(1) = "B" Main: somebit = 0 DEBUG somearr(somebit), CR 'gives me "A" DEBUG somearr(~somebit), CR 'I would like "B" but I get a crash somebit = 1 DEBUG somearr(somebit), CR 'gives me "B" DEBUG somearr(~somebit), CR 'I would like "A" but I get a crash GOTO Main END
somearr VAR Byte(2) somebit VAR Bit ix VAR Bit Reset: somearr(0) = "A" somearr(1) = "B" Main: somebit = 0 DEBUG somearr(somebit), CR 'gives me "A" ix = ~somebit DEBUG somearr(ix), CR 'give me "B" somebit = 1 DEBUG somearr(somebit), CR 'gives me "B" ix = ~somebit DEBUG somearr(ix), CR 'gives me "A" GOTO Main END
What you're trying to do with this, is beyond me:
somebit, somebit+1 and somebit-1 all make sense, but not much else. You are aware that ~ is the negation operator?
A var byte
B var byte
A = 1
B = ~A
B = -1
How do you define a NEGATIVE binary BIT? I know of NO definition. In 10 years I've never seen a Stamp "crash", what does it do when it "crashes?
Bruce Bates
<!--StartFragment -->
~%1100 eq. %0011
It doesn't make it negative. Unless I'm really missing something. I use the ~ operator all the time, it just doesn't seem to work when applied as an expression to reference an array element. Here's a more real world example:
This approach (for me, anyway) is really handy as I propagate the direction bit through a lot of state machines, servos, etc. Again, I can use the lower example in my first post as a workaround, but it's clunkier than just using the ~ on my bit.
As far as the "crash" -- I've never seen it either -- it's the only way to describe what happens. When I compile and run my very first example at top, the debug screen goes wacky -- basically printing only characters up to the "~somebit" then it blanks and flashes a lot. When I compile the workaround it's just dandy.
Sorry, my error. I guess you'll have to ask Jeff Martin from Parallax.
Very strange "crash" results. Jeff will want to know about that too, although that's a compile time error, not a run time error.
Bruce Bates
motor(~turndir)
if turndir=0, then ~turndir=65535
and if turndir=1, then ~turndir=65534
If you have a bit variable,
turndir VAR bit
turndir = ~turndir
that will work fine, because it picks off bit0 for the result, even though the intermediate calculation of ~turndir is a word. But that doesn't happen when you use it as an array index.
Tracy Allen
www.emesystems.com
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Ahhhh...I just looked it up....the documentation says all the unary operators work in 16 bits. I just never thought about correctly. Thanks so much for saving me days of hair-pulling.
In terms of elegant (and easy to read) workaround, I would think something like this would work?
Bean -- I just saw your post while previewing this one. That would work in this case, and is much simpler. THANK YOU. I see only trees, no forest. Although I have few state machines I've been trying out that use two bits (not 1), and I think I'd have to use an approach similar to the above.
